-   Tools (http://www.diychatroom.com/f29/)
-   -   Black oxide drill bits on metal (http://www.diychatroom.com/f29/black-oxide-drill-bits-metal-114064/)
dasjambo 08-15-2011 12:04 AM
Hey there everyone, I've got an amateur question. I locked my bike with a u-lock, and now can't find the key. After searching for it for days, I'm giving up on the key. So now I need to drill through the lock. I have a DeWalt drill with black oxide drill bits--can I just take the drill to the key hole, or would that damage the bit since its metal on metal?
Giles 08-15-2011 12:36 PM
I think you would be much better off to Buy--beg--borrow a grinder with metal cutting wheel (disc). It could be burned off if you had the right torch. I would suspect that all componets of the lock would be hardened steel--if it is quality.
Some cheaper Chinese locks can be sawed with hacksaw:thumbup:
WirelessG 08-15-2011 01:21 PM
I agree with Giles on the grinder. If you have to drill, put some 3 in oil on the lock before you start drilling to keep the bit cool. If the steel is hardened, you will likely dull the bit, but btwist bits are cheap.
