Black & Decker BT2500 Table Saw - Tools - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 11:19 AM   #1
DIY Padawan
CaptainMarvel's Avatar
Question
Might any of you have any knowledge/thoughts about the Black & Decker BT2500 Table Saw?
I have an opportunity to pick one up for about $125 … but I wanted to run it by the experts first.
(mind you, I am strictly a DIY/Home Hobbiest level project/woodworker–not a professional or any intention of becoming one)
Thanks for any comments, insight and/or advice you can provide.
TOM
CaptainMarvel is offline   Reply With Quote
Old 05-13-2013, 11:23 AM   #2
Rewards Points: 528
Keep looking on CL. You can find better brands selling for same or less.
I have found at least where I live that I can buy Delta contractor saws for 100 or less. Much better saws.
framer52 is offline   Reply With Quote
Old 05-13-2013, 02:56 PM   #3
DIY Padawan
What would be the objection(s) to this particular saw, though?
Old 05-13-2013, 04:02 PM   #4
Rewards Points: 13,254
http://www.cpsc.gov/en/Recalls/2002/...r-Table-Saws-/
Old 05-13-2013, 04:04 PM   #5
DIY Padawan
Originally Posted by joecaption View Post
i saw that …. but then I also found some additional info concerning the recall – as follows:
”Check the date code – If the date code is from 200128-CT through 200148-CT, then it must be repaired. Note: id the date code is followed by an “R” your saw has already been repaired. The date code is located on the front of the tool on the nameplate.”
So, I guess I would need to check the date code on the name plate of the saw – to see if it was made after the recall/repair
Black and Decker Workhorse gulbworks Tools 15 05-22-2015 01:28 PM
Black and Decker 36V Lithium Trimmer LST136 dstorjoh Tractors & Mowers 6 04-30-2012 10:36 PM
Black and Decker KS890ECN saw - blades? CoconutPete Tools 14 04-04-2012 09:39 AM
Black and decker 5140 spade handle needs spade handle toolaholic Tools 3 01-23-2012 07:25 PM
Powered outlet on table saw outfeed table? b_corwin Electrical 11 04-12-2010 07:23 PM
