Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-22-2010, 05:45 PM   #1
Wire Chewer
Red Squirrel's Avatar
Bit slips inside chuck when drilling, what am I doing wrong?
When I'm drilling into cement with my Dewalt hammer drill, often the bit will end up slipping inside the chuck, and getting grinded in the process. This is both bad for the drill and the bit itself. I end up getting the job done by continuously tightening it, but no matter how tight I put it in, it will always happen.
Is this normal, or could I be doing something wrong?
If it matters, I occasionally spray water on the bit to keep it cool.
Old 12-22-2010, 06:43 PM   #2
Tileguy
Bud Cline's Avatar
Not familiar with that particular tool - what type of chuck does it have?
Is it SDS?
Old 12-22-2010, 06:58 PM   #3
DIY Hack
Mr Chips's Avatar
It's pretty normal on these keyless chucks, especially if you are really pushing on the drill. If it was an old school Jabobs chuck with a key (or an SDS) you wouldn't have this issue.
I have two suggestions that should help:
1: look for drill bits that are manufacured with "flats" on the shank end. This will help a lot
2: If you find yourself really bearing down on the drill, DON'T! when you push down in rotohammer mode you really make the tool less effective. Let the machine do the work, you should just be holding it straight
EDIT: a third suggestion is to pull the bit up out of the hole a little more often. this will help with dust removal, which will keep the bit from binding ( and ultimately slipping). The water may actually be making it worse, as it may be causing the dust to cake up in the flutes of the bit, making it harder for the bit to get the dust out of the hole
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 12-22-2010, 06:59 PM   #4
DIY Hack
Mr Chips's Avatar
Is it SDS?
from his description I'm willing to bet its a standard keyless chuck, not SDS
Old 12-22-2010, 07:50 PM   #5
Tom Struble's Avatar
and the dewalt keyless chucks are known to be a problem
Tom Struble is offline   Reply With Quote
Old 12-22-2010, 09:08 PM   #6
hvaclover's Avatar
The chuck won't tighten well on some of the older De Walt stuff. I had to use two adjustable pliers to tighten my De Walt hammer drill so the masonry bits would not slip.
When I switch to my newer Milwaukee hammer drill I have no problem.
The chucks are better than the ones the De Walt uses.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 12-23-2010, 10:03 AM   #7
Wire Chewer
It's a key chuck, but the end of the bit and the way it goes in, is basically the same as keyless. There's not much as far as something for it to really grab on to and hold the bit steady.
Old 12-23-2010, 02:19 PM   #8
If it were me i would take and grind it flat on both sides. And when you put in in the chuck put the pointed part's of the bit in the open parts of the chuck and tighten. I bet it won't slip now. I do that to some drill bit's i use in my dewalt keyless chuck.
del schisler is offline   Reply With Quote
Old 12-26-2010, 11:03 PM   #9
Wire Chewer
hmm not a bad idea, I'll have to try this.
drilling into steel door all the way thru for inside security bar install docjlb Building & Construction 4 12-18-2010 05:48 PM
Malibu transformer installed inside, is this wrong? walkdmc Electrical 6 10-03-2010 09:44 AM
B & D chuck Jim F Tools 1 09-09-2010 01:22 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
did i fry my hammer drill's chuck ? amakarevic Tools 5 04-15-2008 02:48 PM
