Between These 2 Miter Saws? - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-17-2014, 10:04 AM   #16
Rewards Points: 874
Originally Posted by ToolSeeker
https://www.google.com/url?sa=t&rct=....61535280,d.aW Jim I hope this works. The video is pretty good.
That's the one I bought but now I'm thinking of returning for the on Joe has.
Mstrlucky74 is offline   Reply With Quote
Old 02-17-2014, 11:44 AM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
That one is a little like the one Joe has. There is nothing wrong with using a jig like that, if it makes the job easier for a person, that is what they should do. As many thousand feet of ceiling mold I ran, I would get mixed up when I had my mind somewhere other than on cutting the molding.
One place that always drove me nuts was when putting 1/4 round, not shoe mold, on the ceiling on a porch, for some reason I would make a lot of the cuts wrong, there was no up or down place, it was all the same not like ceiling mold, which usually one side is thick and the other thin. LOL
One thing I did when running ceiling mold, and I didn't have a cut man, is make the measurements, cut the pieces and glue and pin them together on a table I made out of 3/4 plywood on a set of horses, it sure saved a lot of climbing up and down a ladder.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-17-2014, 12:25 PM   #18
Rewards Points: 5,974
Something that has helped me with crown is take 2 small pieces mitered for the inside corner and tack then together. Make this a perfect fit for the corner hold it up in the corner and take a pencil and mark the bottom use this on all 4 corners using the same pieces. then snap a line between the marks. This will show all the way around where the bottom of the crown should be. This way you don't have to worry about your piece twisting
The Following User Says Thank You to ToolSeeker For This Useful Post:
hand drive (02-17-2014)
Old 02-17-2014, 12:52 PM   #19
AHH, SPANS!!!
Rewards Points: 1,166
I go half way each time as opposed to popping the line across the entire room. this helps if the middle is high or low and keeps the crown the same distance from ceiling everywhere. mostly though I just measure down a few spots and make a tiny hash mark to follow. chalk lines can drop to much chalk in finished houses.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
ToolSeeker (02-17-2014)
Old 02-17-2014, 02:25 PM   #20
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
the other issue with chalking a line from corner to corner is if the ceiling isnt perfectly flat it can cause your pieces to sit down too lown and you will have a wicked twist in it for it to meet the ceiling or a nasty gap.. for this reason i prefer cutting blocks that match where the crown will lie on the wall and ceiling. ive had far greater success with this method
woodworkbykirk is offline   Reply With Quote
Old 02-17-2014, 03:41 PM   #21
Ole Wood Worker
BigJim's Avatar
Rewards Points: 390
If you have a sag in the ceiling, popping a line and keeping the bottom of the trim on that line and roll the top out will make the ceiling look straight. It is easier to see a sag than to see the twist in the ceiling mold. I know that it is sad that some new construction is like that but it is. I wanted my trim to look good so that is the decision I made so it would. And yes I had to plane some of the back off at the top for a close fit. I hated doing that but that is the way it was.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Old 02-21-2014, 06:03 PM   #22
Rewards Points: 149
http://www.bing.com/videos/search?q=...34464B931ED229
You can cut flat.
bote110 is offline   Reply With Quote
The Following User Says Thank You to bote110 For This Useful Post:
Mstrlucky74 (02-21-2014)
Talk me into or out of these miter saws (and stands) Dave88LX Tools 31 12-02-2013 10:43 AM
Performax sliding compound miter saws for 3.5" crown? Bradeno Carpentry 8 12-27-2012 07:20 AM
School me on miter saws anonymoususer Tools 8 03-26-2011 01:19 PM
Need advice or feedback on miter saws mwehnes Carpentry 10 02-21-2007 08:48 AM
