The Better Tool For Cutting/splicing Romex? - Tools - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 03:27 AM   #1
Rewards Points: 33
The better tool for cutting/splicing romex?
This? http://www.amazon.com/Ridgid-21438-R...5552764&sr=8-7
or
This? http://www.amazon.com/45-025-IDEAL-L...5552817&sr=8-1
It seems like it can do everything the more expensive tool can. Has anyone used both of these that can help?
Sliding Man is offline   Reply With Quote
Old 09-09-2011, 07:40 AM   #2
DIY staff
Rewards Points: 7,174
I've got a pair like the top picture--They are made by Kline----I like them and have had a few others run out to buy them after they borrowed mine.
I am not in a Romex area so I don't have much use for them--But they do work well.---Mike---
Sliding Man (09-10-2011)
Old 09-09-2011, 08:16 AM   #3
A Little Of Everything
Rewards Points: 1,364
or
If you actually plan to use it more than once, go with the former. I've got 3 pair of wire stripper/cutters. One is of high-quality, the other two are not. There is a HUGE difference.
That said, I've never used the "Lil Ripper Stripper" but don't believe there is any way that a plastic $5 tool is going to do the job you want it to. In fact, I doubt seriously that it will work at all.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
Old 09-09-2011, 08:34 AM   #4
Rewards Points: 56
Actually, mine aren't that "fancy", but if the second one is what I believe it is, it's not an either/or thing. I believe that the second one has a blade of sort inside it, which is for the purpose slicing the outer sheathing on NM or "Romex" cable, so that you can access the individual wires. Afer you have sliced the sheathing with that tool, and cut it out of the way, you would use the first tool, or something similar, to strip, cut, and bend the individual wires.
The Following User Says Thank You to DexterII For This Useful Post:
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 08:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 03:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 11:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
