Best Way To Cut DIN Rail? - Tools - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 08:07 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
best way to cut DIN rail?
I need to cut a DIN rail to fit on a server rack. I tried using a grinder with a cut off disc but after spending a good half hour on it, it barely has a scratch, and it feels like I'm about to go deaf. There's got to be a better way.
I know there are DIN rail cutter tools but they're hundreds of dollars. For a one or two time job, there's got to be a cheaper way. I'm even wondering if a machine shop would do it... but is there an easier DIY way? I can keep grinding at it and eventually it will be cut, but it just seems so messy and long.
Old 01-30-2012, 08:11 PM   #2
Rewards Points: 12,802
Ok we give up what is Din rail?
Old 01-30-2012, 08:18 PM   #3
Wire Chewer
Rewards Points: 46
Sorry, I figured it would be common knowledge. It's to mount "DIN" Compatible components, it's a standard.
Old 01-30-2012, 08:43 PM   #4
Wire Chewer
Rewards Points: 46
Ok I finally got it cut, and I'm a retard. Only AFTER it was cut, I realized I put a masonry blade. LOL
The Following 2 Users Say Thank You to Red Squirrel For This Useful Post:
VIPlumber (01-31-2012), woodworkbykirk (01-30-2012)
Old 01-30-2012, 09:07 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Hack saw works too!
Old 01-31-2012, 03:42 AM   #6
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I cut through a high security padlock in 40 sec with no noticeable wear on the disk with one of these:
http://www.amazon.com/Dremel-EZ406-C...m/B000FBLRVA/2
I estimate that it would make a very clean straight cut in a DIN rail in less than 10 seconds.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-01-2012, 12:04 AM   #7
Rewards Points: 506
Use aluminum rail and cut with tin snips. Much quieter. File any burrs. Still quieter.
In this age of power tools we've forgotten the basics.
jlmran is offline   Reply With Quote
Old 02-01-2012, 08:54 PM   #8
Wire Chewer
Rewards Points: 46
This rail is quite thick, don't think tin snips would have done the job.
Never thought of a hacksaw though that probably would have worked too. Next time I'll try with the right blade on the grinder first! lol
Old 02-01-2012, 09:17 PM   #9
Rewards Points: 506
FYI - Wiss bulldogs will cut 16 ga steel. Granted, DIN rail has some bends in it which could be a challenge. Aluminum DIN is a breeze to work with and still mounts components very well.
Installing chair rail over uneven sheetrock krazykarr Drywall & Plaster 10 12-20-2011 12:51 AM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
Unique Chair Rail Obstacle mormegil Interior Decorating 4 06-03-2011 07:56 PM
Missing stair rail BlueBSH Remodeling 4 02-03-2010 06:41 PM
Safety rail for loft Pam Remodeling 5 02-26-2007 02:55 PM
