Best Tool To Self Tap Into Metal - Tools - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 12:21 AM   #1
Rewards Points: 53
Best tool to self tap into metal
I am using self tapping screws to screw into metal (not that thick). What is the best type of drill to use for this?
tucker0104 is offline   Reply With Quote
Old 03-26-2013, 12:27 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,958
Drill? Self tapping? I think your missing the idea of self tapping....it drills the hole for you....unless your talking a something bigger than a #10 screw...
Old 03-26-2013, 12:47 AM   #3
Remodeler
Rewards Points: 330
Are you using self drilling screws or self tapping screws?
You can get screws that have a drill point built right into the screw, they work great for thin metal even up to 3/16" or more. You can also get self tapping screws that will cut their own threads but require a hole to be drilled first. For these use a twist drill bit of the appropriate size to create the pilot hole.
For driving either type of screw a cordless drill or cordless impact driver works best. You need slower speeds and higher torque. You must be careful as the screws get tight, as the screw head bottoms out or the screw will often snap off if the screw is over tightened. A cordless drill with a clutch is a good option.
iamrfixit is offline   Reply With Quote
Old 03-26-2013, 01:22 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Not sure of your question. What is your application?
If you're adding ground screws to old style metal boxes I use this.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-26-2013, 05:15 AM   #5
Rewards Points: 13,968
I use an impact driver for almost everything.
Metal roofing, gutters, drilling ECT.
Far more torque then a cordless drill.
Old 03-27-2013, 09:50 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
If they are sheet metal screws, I just punch a hole with an awl. Be careful not to punch the hole too big. If they are self drilling, run them with a battery drill. They'll make their own hole and start threading. Some self threading screws need a pilot hole. In that case, drill the absolute smallest hole that the tip will start into.
Old 03-27-2013, 09:10 PM   #7
Concrete & Masonry
Rewards Points: 620
I use an awl as well, and it makes the installation much, much easier. For corrugated steel roof/ceiling/siding, I wouldn't think of any better way that creating a pattern sheet, and using an awl to pre-punch all the holes before installing. A few minutes on the front-end will save you hours and lot's of frustration on the back-end..............
jomama45 is offline   Reply With Quote
Old 03-28-2013, 07:38 AM   #8
Tool Geek
PaliBob's Avatar
Greenlee has six sizes of Drill and Tap tools.
Do a search on Amazon for Greenlee DTAPKIT
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-28-2013, 09:49 AM   #9
Lord of Slums
Rewards Points: 1,974
I am accepting challengers to my race. You with the self tapping screws and me drilling pilot holes before the screwing. I will be much faster each time.
mj12 is offline   Reply With Quote
Old 03-28-2013, 05:35 PM   #10
Tool Geek
PaliBob's Avatar
I was off topic because my example is for tapping for regular threaded screws not self tapping screws.
I always thought of self tapping screws as NOT requiring a pilot hole but now I see that sometimes sheet metal screws are being referred to as self tapping screws.
The O.P. did not clarify which type but now I think he is referring to regular sheet metal screws which do require a pilot hole.
The Self-Tapping screws pictured do NOT need a pilot hole.
My use of the Drill & Tap tool has been for adding Green Ground Screws in old style Electrical boxes that did not have a ground screw. That style Drill & Tap would not work for thin sheet metal.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-28-2013, 05:54 PM   #11
Anybody have them in store?
Hardway is offline   Reply With Quote
Old 03-28-2013, 06:08 PM   #12
Tool Geek
PaliBob's Avatar
Greenlee tools can most most likely be found at at Grainger or local Electrical Supply houses. This is not a Big Box Store item
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-29-2013, 03:21 PM   #13
That's a challenge I would accept. There is no way you can be faster. As long as I am using correct self tapping screws I will only need one step: drill/drive in one operation.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
r0ckstarr (04-24-2013)
Old 04-05-2013, 02:11 AM   #14
Drill a pilot hole in advance when you are drilling in the hard materials. Use self-drilling self-tapping screws to drill into metal, it will save your time and labor. Thanks!
adlermark321 is offline   Reply With Quote
Old 04-24-2013, 05:09 AM   #15
Answer
Using an impact on self tapping screws is usually difficult. An impact is easier on thick metal but still difficult, but if you are trying to go through thick steel (1/8" -1/4") you need to not only use a regular high speed drill but you will also need to buy what I have always called badass screws (doubt that's the manf name). They are similar to the self tapping screws pictured in the above post but the drill/tap flights are about 1/2" long vs 1/8. AMAZING SCREWS. Expensive, but amazing.
They also have self tapping screws that cut their own threads but require a pilot hole. Much cheaper but again they require a pilot hole.
BrandonK29 is offline   Reply With Quote
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 03:18 PM
metal tool shed sheba Building & Construction 2 10-21-2012 03:26 PM
Metal roof questions Zedman53 Roofing/Siding 20 02-04-2012 11:32 AM
metal vs shingles av-geek Roofing/Siding 39 01-24-2012 04:25 PM
Flat metal bending (tool) SFX Group HVAC 3 04-19-2011 07:25 AM
