Best Tool For Grinding Steel - Tools - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 01:07 AM   #1
Rewards Points: 392
Best Tool for grinding steel
I want to put a larger A-frame jack on my trailer and it currently has a 2" outer diameter pipe on the jack. I wan to use a jack that has a 2.25 inch outer diameter pipe. The Upper mounting metal where the jack goes has a hole that works just fine, but right below it is a secondary piece of 1/8 sheet metal that only has a 2" hole.
I'm trying to figure out the best and lowest cost way to bore this out. I'll be working from a 2" hole from the top so I only have so many options..
Should I get a die grinder and a grinding bit? I'm thinking the angle grinder style material that i use to sharpen the mower blade would be a good material choice, but they don't come in 1" size bits do they?
Should I try to use a hole saw?
What tool can I use that won't wear out completely during this job and cost an arm and a leg?
Let me know if you can suggest any links for how best to do this job..
zootjeff is offline   Reply With Quote
Old 07-14-2011, 05:32 AM   #2
Rewards Points: 78
Without getting too exotic, the cleanest and neatest way to do it would be with a hole saw. You will want to clamp a piece of 1 by or 2 by under the hole, to provide something for the pilot.
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 07:31 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 02:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
