Best Recip Blade For Hard Nails/concrete Nails - Tools - DIY Chatroom Home Improvement Forum
Old 11-29-2011, 05:57 PM   #1
Best recip blade for hard nails/concrete nails
Hi! Thanks for reading--We are removing hardwood flooring, tongue and groove. We're halfway done. This DIY home, circa 1950, has LOTS of what I call 'hard nails' but you may know as concrete nails. They are angular rather than round. The heads are recatangular. They seem to be harder material than most nails. They are every foot in the groove. The only way we've found to salvage this flooring is to gently pry up the plank then sawzall the hard nails. But the blades are getting worn down too fast. What, if any, blade will stand up to at least 100-200 of these nails before it needs to be changed? We've determined that the coarse-tooth blades work better than fine-tooth. Still, I'm hopeful there is a specialty blade that would be worthwhile. We've spent over $100 on blades. This isn't terrible since the flooring is going to save us 1000-2000 bucks and the whole house was a gift because it was going to be demolished. Anyway, thanks again. Any suggestions?
scotters is offline   Reply With Quote
Old 11-29-2011, 08:30 PM   #2
liscenced electrician
Rewards Points: 538
perhaps an angle grinder with a cut off disc?
jimmy21 is offline   Reply With Quote
Old 11-29-2011, 09:32 PM   #3
In a little over my head
Rewards Points: 706
I think Jimmy may be on to something. If you have air, a die grinder with a "ziz wheel". Or a muffler cut off tool (same thing, with a guard.) If you don't have air, you can spin the cut-off wheel mandrel with a cheap trim router with the base removed.
http://www.harborfreight.com/1-4-qua...der-52847.html
http://www.harborfreight.com/1-4-qua...ter-44914.html
http://www.harborfreight.com/1-1-2-h...ack-34749.html
(I'm not recommending HF tools. Just showing pictures and a cheap way to do it. Better tools are usually [always] better.)
ratherbefishing is offline   Reply With Quote
Old 11-29-2011, 10:55 PM   #4
Rewards Points: 502
you can get 4.5" angle grinders for $50
forresth is offline   Reply With Quote
Old 11-29-2011, 10:59 PM   #5
I was in a similar situation last year when remmodeling our place last year. I found that using a pair of water pump pliers & scrap piece of plywood worked great.
VIPlumber is offline   Reply With Quote
Used wrong nails for joist hanger odlaw Remodeling 14 05-28-2011 10:26 AM
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 06:44 AM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 04:26 PM
Free Recip saw blade Brik Building & Construction 2 01-16-2007 04:40 PM
