Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 09-29-2006, 01:26 AM   #1
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
Best reasonable stud finder???
What is the best reasonable stud finder out there? I have a craftsman and it cant find a stud if it was right on it.
Sellncars is offline   Reply With Quote
Old 09-29-2006, 10:11 AM   #2
Master Craftsman
Big Dave's Avatar
Probably your wife. She found you didn't she. Seriously though I just use my knuckle or if there is a receptacle, find out which side the stud is on and measure 16 inch increments from there.
Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 09-29-2006, 07:29 PM   #3
General Contractor
joasis's Avatar
I use a Zircon, and my wife says is it very accurate, since it doesn't go off when I am around....actually, it works, but get in the habit of doing like Dave says, and you can get on the mark without the gadgets.
joasis is offline   Reply With Quote
Old 09-29-2006, 08:12 PM   #4
World famous jerk.
I have had various stud finders over the years, and they all suck. The best stud finder is the one God put on your finger... your knuckle. I can find studs under plaster and lath. It does take a bit of practice. Lately, I've been using a cow magnet. It finds the lath nails or the drywall screws or nails. Cow magnets work super great with metal studs. It's the way to fly on them.
mdshunk is offline   Reply With Quote
Old 09-29-2006, 08:21 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
I've had a few Zircons that worked well
I'd recommend the slightly fancier one that has the depth ("deep scan") switch and also checks for hot wires automatically (and by switch)
slickshift is offline   Reply With Quote
Old 10-02-2006, 08:25 AM   #6
They're all fixer-uppers
J187's Avatar
If you use a stud finder the real secret is as follows
1. Allow the stud finder to calibrate when you first hit the button before moving it.
2. Move very slowly from side to side
3. do you absolute best to keep the stud finder flat and level against the wall.
4. Make numerous passes after it indicates a stud. The most common spot that the edge is indicated is probably pretty close to the edge.
J187 is offline   Reply With Quote
Old 10-03-2006, 09:29 PM   #7
Sellncars's Avatar
Thank's for all the reply's guys. I may try a Zircon, then again, i may strengthen my knuckles.
Thanks,
Sellncars
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
what's a good stud finder? handbanana Tools 16 12-07-2007 04:01 PM
Is this a reasonable price to wire a basement? Webguy64 Electrical 12 06-07-2007 10:41 AM
Finding AC wires with Ryobi stud finder darsunt Tools 4 03-21-2007 08:43 PM
Stud Finder problem... kalaniwavo Carpentry 4 02-26-2006 08:24 PM
