Best Drill Bit For Steel? - Tools - DIY Chatroom Home Improvement Forum
Old 08-22-2013, 01:20 PM   #1
n2omichael's Avatar
Rewards Points: 115
Best drill bit for steel?
I need to drill a1/4" hole in an 8" I beam, it's a remote job and I don't want to be running into town to buy bits, can someone tell me what the BEST drill bit would be for this application?
Thanks!
Michael
n2omichael is offline   Reply With Quote
Old 08-22-2013, 03:09 PM   #2
Civil Engineer
Rewards Points: 4,522
I have successfully used titanium nitride bits to do a similar job. You need a high torque drill, and plenty of lubricant. Low speed is better than high speed based on my experience, but you can actually get charts that show required speed for steel based on bit size. You can do this job using cobalt bits, or even black oxide bits. With the black oxide, you only get a few holes per bit. Make sure you get metal drilling bits.
Old 08-22-2013, 04:17 PM   #3
Rewards Points: 444
I just visited with the knowledgeable counter man at the machine shop I do business with and ask if a person walked in off the street to buy a bit and wanted to drill mild steel he would recommend high speed steel bits. If steel in the range of grade 8 was to be drilled he would recommend cobalt.
Your 1/4" bit rpm calculates to 1,440 with a cutting speed of 90 feet / minute for mild steel. A little slower would be ok. Harder / tougher material will have less than 90 fpm cutting speed and will calculate to less rpm. Formula: cs x 4 divided by the diameter.
Use a cutting oil not lube oil, available in aresol and an occasional squirt is all that's needed. Water would be better than any lubricating liquid.
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 08:00 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 10:08 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 10:53 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
