Bench Grinder - Tools - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 10:47 PM   #1
Rewards Points: 77
Bench Grinder
I'm looking for a bench grinder. Truly can't spend more than $70 on one. What are some budget bench grinders out there that give real bang for your buck?
Justins1171 is offline   Reply With Quote
Old 11-21-2011, 06:56 AM   #2
Rewards Points: 106
I haven't paid much attention to them, but doubt that you will have many options in the $70 range for a new bench grinder, and certainly nothing that is going to give you any significant "bang for your buck". Do you have any particular plans for it? If it's for sharpening lawn mower blades, probably anything that you find will work, although I started doing mine in the vise with a disc grinder several years back, but if you plan to get into fabricating, etc., where it might see some harsher use, I would watch for a used, older, Wilton.
Old 11-21-2011, 09:18 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
http://www.harborfreight.com/catalog...=bench+grinder
Old 11-21-2011, 10:35 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
http://www.sears.com/shc/s/p_10153_1...=1321893236991
I have one that I have hard felt on for polishing carving gouges and it does a good job.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-21-2011, 03:09 PM   #5
In a little over my head
Rewards Points: 706
My dad gave me a cheap one several years ago. It was probably from Harbor Freight.The motor housing was larger diameter than the wheels, significantly limiting it's usefullness (think lawnmower blades.) I put it aside. when I pulled it back out to dedicate to sharpening lathe gouges, the switch was bad. A new 20 Amp switch got it going. It works fine now, for what I use it for. But it's still limited as a general purpose grinder.
Be aware of the wheel/motor diameters.
ratherbefishing is offline   Reply With Quote
Old 11-23-2011, 08:21 PM   #6
Rewards Points: 502
craigslist
you might also want to consider an angle grinder instead. I use mine for everything it seams.
forresth is offline   Reply With Quote
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 05:09 AM
Good bench grinder junkcollector Tools 0 10-07-2010 07:29 PM
20 amp circuit required for new bench grinder?? sdyck Electrical 6 04-05-2009 03:25 PM
Retiling Shower Bench - HELP Jamboy Remodeling 4 10-09-2007 10:03 AM
Retiling Shower Bench - HELP Jamboy Building & Construction 2 10-07-2007 11:56 AM
