Belt Sander Repair - Tools - DIY Chatroom Home Improvement Forum
Old 09-10-2006, 03:44 PM   #1
Question
Belt sander repair
I have a Craftsman 3 inch belt sander and the sleeve bearing on the drive roller has worn out. I removed the retaining ring on the roller but have no idea what to do next to remove the roller. Any advice?
longtimealaskan is offline   Reply With Quote
Old 09-14-2006, 10:17 AM   #2
More Power
if you go to sears.com and go to the parts section, you can pull up the parts diagram with the model number. That may help you to see what's connected to what and how it should come apart.
vinman is offline   Reply With Quote
Dryer Belt KB Services Appliances 2 03-07-2008 01:35 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 02:02 AM
Belt Sander? or other type... KUIPORNG Tools 7 04-18-2007 03:51 PM
Remove epoxy with ROS or belt sander? donnydoon Building & Construction 7 12-09-2006 10:33 AM
Drum Sander -vs- Disk Sander BlueGuy Flooring 7 08-20-2006 10:44 PM
