Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 04-18-2007, 11:34 AM   #1
Belt Sander? or other type...
I am looking into buying a sander... looks like Belt Sander is the best bet for me... as looks like it can do most of the wood working stuff...
as a DIYers... requires sanding on various situation... is Belt Sander is the best bet to acquire which got most multi-purpose usage?
thanks...
KUIPORNG is offline   Reply With Quote
Old 04-18-2007, 12:07 PM   #2
Master Craftsman
Big Dave's Avatar
Belt sanders are great for removal of alot of stock quickly but not the best for finish sanding. With a belt sander you will always need to sand with the grain or else it will cause scratches that will show up when you stain and finish your project.
A Random Orbital sander is a better choice. You can get an aggresive grit for heavy removal or a finer grit for finish sanding plus you don't have to worry about which way you sand your project.
For sanders I would recommend the Porter-Cable line. I've always thought their sanders and routers were superior to any one elses.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 04-18-2007, 01:15 PM   #3
One reason for me to consider belt sander is sometimes I need to trim the wood a little bit to get a perfect fit... Can orbital sander do that? Think of installing hardwood on stairs as an example...
Old 04-18-2007, 01:27 PM   #4
Master Craftsman
Big Dave's Avatar
If you need to trim a little off of a peice of wood then I would recommend a small hand plane
With an aggresive paper the orbital will remove wood rather quickly.
Old 04-18-2007, 02:12 PM   #5
I have a visa-pak black and decker 7.2 V handheld small trigangular sander... are those similar to orbital sander... doing similar action which is vibrating/shaking a lot... Just want to have an idea how orbital sander works...
Old 04-18-2007, 02:52 PM   #6
Master Craftsman
Big Dave's Avatar
This is the one I would recommend.
http://www.lowes.com/lowes/lkn?actio...43K&lpage=none
Old 04-18-2007, 03:47 PM   #7
I'd second this advice. Using a belt sander for fitting joints is like using a blender to peel a potato.
If you want a general purpose sander, get a Random Orbit 5" palm sander. I too like the porter cable model.
For trimming joints, get a chisel, and a block plane, and learn how to keep them sharp. It's much quicker, more accurate, and infinitely more pleasant than using a sander to remove wood.
NateHanson is offline   Reply With Quote
Old 04-18-2007, 03:51 PM   #8
Thanks... for the advice... I most likely will get an orbital sander after reviewing..
Dryer Belt KB Services Appliances 2 03-07-2008 01:35 PM
Remove epoxy with ROS or belt sander? donnydoon Building & Construction 7 12-09-2006 10:33 AM
Belt sander repair longtimealaskan Tools 1 09-14-2006 10:17 AM
Drum Sander -vs- Disk Sander BlueGuy Flooring 7 08-20-2006 10:44 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
