-   Tools (http://www.diychatroom.com/f29/)
-   -   Belt Sander? or other type... (http://www.diychatroom.com/f29/belt-sander-other-type-7871/)
KUIPORNG 04-18-2007 10:34 AM
I am looking into buying a sander... looks like Belt Sander is the best bet for me... as looks like it can do most of the wood working stuff...
as a DIYers... requires sanding on various situation... is Belt Sander is the best bet to acquire which got most multi-purpose usage?
thanks...
Big Dave 04-18-2007 11:07 AM
Belt sanders are great for removal of alot of stock quickly but not the best for finish sanding. With a belt sander you will always need to sand with the grain or else it will cause scratches that will show up when you stain and finish your project.
A Random Orbital sander is a better choice. You can get an aggresive grit for heavy removal or a finer grit for finish sanding plus you don't have to worry about which way you sand your project.
For sanders I would recommend the Porter-Cable line. I've always thought their sanders and routers were superior to any one elses.
KUIPORNG 04-18-2007 12:15 PM
One reason for me to consider belt sander is sometimes I need to trim the wood a little bit to get a perfect fit... Can orbital sander do that? Think of installing hardwood on stairs as an example...
Big Dave 04-18-2007 12:27 PM
If you need to trim a little off of a peice of wood then I would recommend a small hand plane
With an aggresive paper the orbital will remove wood rather quickly.
KUIPORNG 04-18-2007 01:12 PM
I have a visa-pak black and decker 7.2 V handheld small trigangular sander... are those similar to orbital sander... doing similar action which is vibrating/shaking a lot... Just want to have an idea how orbital sander works...
Big Dave 04-18-2007 01:52 PM
This is the one I would recommend.
http://www.lowes.com/lowes/lkn?actio...43K&lpage=none
NateHanson 04-18-2007 02:47 PM
I'd second this advice. Using a belt sander for fitting joints is like using a blender to peel a potato.
If you want a general purpose sander, get a Random Orbit 5" palm sander. I too like the porter cable model.
For trimming joints, get a chisel, and a block plane, and learn how to keep them sharp. It's much quicker, more accurate, and infinitely more pleasant than using a sander to remove wood.
KUIPORNG 04-18-2007 02:51 PM
Thanks... for the advice... I most likely will get an orbital sander after reviewing..
