Bearing Press / Arbor Press - Tools - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 03:35 PM   #1
bearing press / arbor press
I just picked up a small 1 ton arbor press. I need it to remove/install some small bearings ~ 10mm - 30mm range.
What I still need is some type of pieces or fixtures that will make the correct fit between my bearing and the square arbor. What are these pieces called? I'm trying to locate a set of small sizes and I'm not sure of exactly what I'm looking for. Any clues appreciated. Thx.
koodawg is offline   Reply With Quote
Old 02-15-2011, 04:25 PM   #2
fabrk8r
fabrk8r's Avatar
I've always just called them "adaptors". A socket the correct size usually works well.
Mandrel and die perhaps?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-20-2011, 10:20 AM   #3
yup...sockets work great. Fashion a pusher that sits in the socket so you dont push on the socket opening. Just use scrap bar stock.
beerdog is offline   Reply With Quote
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
Supporting floor joists on non-load bearing wall? ct9359 Building & Construction 4 07-17-2009 12:59 PM
Bearing wall, HELP me please jamiedolan Building & Construction 7 11-03-2008 11:33 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
