Batteries Dying If Left In The Cordless Tool? - Tools - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 10:55 PM   #1
Batteries dying if left in the cordless tool?
I have the small Makita 10.8V Impact Gun that I love. One issue that I noticed is that if I don't use it for 2 weeks or so, the battery that I left in the drill seems to be dead, BUT the second battery that weasn't in the drill seems to be fully charged.
This leads me to believe that leaving the battery in the drill causes it to discharge. FWIW, I lock the drills trigger so it can't accidentally be turned on.
General is offline   Reply With Quote
Old 12-19-2010, 04:35 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Cold weather kills the charge in Li-Ion batteries. If the second battery has been kept in the same environment as the battery in the tool, then the battery may be marginal. You could switch batteries and repeat the test to see if both batteries exhibit the same condition.
Makita, when they label their Tools as 10.8 Volt, seem to be the only manufacturer that has remained honest about the actual voltage. The other Tool makers have labeled their 3-cell Li-Ion tools as 12 Volt. The voltage of a Li-Ion cell is 3.6V, so three cells make 10.8 Volts Not 12V.
Bosh, I think, was the first one out with a compact 10.8 V Li-Ion tool, but when the competition started calling their new models 12V Tools then Bosh switched to calling their 10.8V tools, 12V tools. The justification was that on a new fully charged 3-cell Li-Ion battery pack, the open circuit voltage can hit 12V. The New Bosh 12V batteries are duplicates of the ones they originally labeled as 10.8 V.
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
tpolk (12-19-2010)
Old 12-19-2010, 07:16 AM   #3
I forgot to mention that, it happens with BOTH batteries. Whatever battery is in the drill seems to die after 4 screws, but the battery that was sitting right next to it and was charged at the same time will seem to have a full charge.
On Makita's website they promote some of the 10.8V tools as "12V Max". I guess everyone is playing the game.
Old 12-19-2010, 12:27 PM   #4
Tool Geek
PaliBob's Avatar
Wow! That sounds like neither battery has enough charge to drive more than four screws. Am I hearing that right?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 12-19-2010, 03:51 PM   #5
Rewards Points: 5,336
Then the lesson learned is leave the batteries out of the tool. I'll have to try that with the 18v Dewalt. But they stay in the truck regardless of the time of year. I plug them in as soon as I get to the job.
Ron
Old 12-20-2010, 03:11 PM   #6
Yes, if left in the gun for a couple weeks. The battery that is not left in the gun has a good charge.
Old 12-20-2010, 03:12 PM   #7
That's not a lesson, that's a band-aid. If other people's Makita's aren't doing this, then there is something wrong with mine.
Old 12-21-2010, 07:16 AM   #8
SDC
SDC's Avatar
Those Makitas, even when the trigger is locked still allow the light to activate. If it is bouncing around in your truck it may be hitting the trigger enough to wear it down.
I have those drill and have not seen the same issues.
David Cookman
www.SDCookman.com / FaceBook
SDC is offline   Reply With Quote
Old 12-23-2010, 07:44 PM   #9
Household Handyman
Rewards Points: 1,408
For what it's worth: I have multiple DeWalt tools which use 18v batteries. I have found that if I leave any of these tools with a battery in them, they will discharge. As you stated, I have left a tool lying on a workbench next to a marginally charged battery. The battery in the tool dies, and the battery not in a tool stays at about the same charge. I now have a habit of pulling my batteries out of tools at the end of each work day. Actually in my work trailer I have a space for all of my DeWalt batteries and can tell if on is not in it's proper place before locking up.
Need Help with re-design ttwiss Remodeling 21 05-08-2010 10:27 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 01:31 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 06:39 PM
Cordless Drill Batteries MrBill_DIY Tools 11 01-15-2009 04:17 PM
Cordless tool brush replacement Joe F Tools 2 10-11-2008 02:21 PM
