The Basics Of The Hammer - Tools - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 11:53 PM   #31
Ole Wood Worker
BigJim's Avatar
Rewards Points: 544
And with a Estwing you wouldn't need to haul around a block of wax that will melt in the heat, or mangle you hammer handle to hang on to, or have to carry two or three extra tools the Estwing will do. A person who will damage himself because the handle of a hammer is steel instead of wood will do just as much damage as they will with any hammer.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-21-2012, 12:30 AM   #32
FWIW I have 2 estwigs; a waffle head 22 oz framer and a 3lb engineers hammer! Both have fiberglass handles! Both were purchased on clearance! Both have been fine for homeowner use!
toolaholic is offline   Reply With Quote
Old 01-21-2012, 12:36 AM   #33
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
What the heck is a 3lb engineers hammer?! Sounds painful!
Really, what's it used for?
titanoman is offline   Reply With Quote
Old 01-21-2012, 02:53 AM   #34
It's a mini sledgehammer! Also called a maul!
Old 01-21-2012, 05:37 AM   #35
Disabled wood vet
titanoman's Avatar
Oh! A single-jack. I just didn't know it was called an engineers hammer.
Learn something new every day (just when I thought I knew it all!).
Old 01-21-2012, 07:02 AM   #36
Never heard single jack! So I'm learning too! I like it to drive 12 inch spikes into 3x5 timbers for borders! Of course I countersink w/ a 3/4 inch forsener bit and predrill the timber w/ a 3/8 bit!
Old 01-21-2012, 07:37 AM   #37
Disabled wood vet
titanoman's Avatar
And a double-jack (2 hands) is anything over 8lbs, so you can sink those spikes like a 16d into butter!
Old 01-23-2012, 03:37 PM   #38
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
aka: Lump hammer or club hammer
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-23-2012, 04:49 PM   #39
Framing Contractor
Rewards Points: 120
I have been framing for 28 years and use an Estwing every day. Of course anymore it doesn't see heavy action due to the use of nail guns. I have had zero problems with wrist or elbow.
Number one tip for using a hammer:
Be sure to hit the right nail!
sixeightten is offline   Reply With Quote
Old 01-23-2012, 05:55 PM   #40
KemoSabe
loneframer's Avatar
I hand banged houses together for around 3 years before we got a gun setup.
I used Estwings for 2 of those years.
A few of the afflictions I dealt with...
Waking up in the morning, having to literally pry my fingers open on my hammer hand because they were locked in hammer grip position.
Couldn't lift my left arm above my chest because of shoulder pain
Stingers in my forearm as well as cramping.
I switched to a Vaughan 24 oz fiberglass and withing a few months had none of the above issues.
Of coarse, having done the math, we were banging roughly 50,000 nails in the average house at about 3-4 weeks per house with 3 guys.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 01-23-2012, 06:07 PM   #41
Busy DIYer
picflight's Avatar
Rewards Points: 150
Would a rubber hammer be easier to use?
picflight is offline   Reply With Quote
Old 01-23-2012, 06:31 PM   #42
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
thats a joke right?
i hear you on the shoulder, elbow, wrist and forearm pain thing lone.. when i went out framing large custom houses that were almost entirely built from engineeered lumber i had the same problem using my 22 oz estwing, i switched back to my japanse nailing hammer to stop the pain just before i bought my stilletto.
we were framing those houses in the winter which meant driving pairs of hand spike every 16" to draw the super hard frozen engineered lumber together then after everying was assembled, then the guns would get used fo finish off laminating.. the guns dont draw together lumber, and they sure as hell couldnt sink the nails in the engineered stuff
woodworkbykirk is offline   Reply With Quote
Old 01-24-2012, 01:48 AM   #43
I have a Hitachi NR90AC3 for framing, Hitachi 15 and 18 gauge finish nailers, a Grex 23 gauge pinner, a Porta Nailer 18 gauge stapler and a Bostitch palm nailer.
Don't use a hammer much these days except for demo work, and the Estwing works great for that.
What do you guys suggest for a good basic hammer for an old guy like me? Keep in mind I'm just a DIY home owner.
itin1200 is offline   Reply With Quote
Old 01-24-2012, 05:24 AM   #44
I like my 16oz plumb(brand) fiberglass handle!
Old 01-24-2012, 10:55 AM   #45
Disabled wood vet
titanoman's Avatar
That's something I never figured out: How many 16 green vinyls in a keg?
The last monster (12,000 sg ft) I built took a couple of those and at least 3 boxes of strip nails.
Between those and all the 8's and deck screws we probably had over 300 lbs in fasteners.
Tags
hammer basics , hammer safety , how to use a hammer , tool basics
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 01:34 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 09:08 PM
Sledge hammer with fiberglass handle... How indestructible are they? xusword Safety 3 04-14-2011 10:13 PM
Rotary Hammer Drill vs Hammer Drill jrepp44 Tools 6 06-29-2010 06:07 AM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
