Backwards Table Saw Blade Rotation - Tools - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 09:10 PM   #1
Stairguy
Millertyme's Avatar
Rewards Points: 508
backwards table saw blade rotation
I was using my powermatic table saw today. I used it in the morning and it was fine. Later in the afternoon i went to use it and after ripping about 1" into a board, the saw started to scream. When i shut it down I noticed the blade was spinning backwards. I have never seen this before. It was about 85 degrees in the shop today and was very humid. Could this cause any kind of contact issues?
Millertyme is offline   Reply With Quote
Old 06-30-2011, 06:14 AM   #2
DIY staff
Rewards Points: 7,174
That's unheard of---That's a 220 motor? The rotation can be switched by changing the wiring inside the motor---I suspect a loose connection inside the motor cover---
Lets see what a sparky says----I would call the manufacturers technical help line,if it were me.
Old 06-30-2011, 06:27 AM   #3
DIY staff
Before you open the motor---check the outlet--make sure you have power on both legs of that 220 line.
Old 06-30-2011, 06:31 AM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Might not hurt to try resetting the breaker altogether, but more than likely the starter windings in the motor are fried
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 06-30-2011, 08:26 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 494
Wow, I have never seen a table saw do that but I did have a 16 inch older Dewalt RAS that would do that if you just turned the switch on. I was told the starter windings were bad. I always would spin the blade by hand in the right dirrection then hit the on switch and it would work fine like that. You can't spin a unisaw like that though. Let us know what you find out.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 04:26 PM
Adjusting Cabinet Saw Trunnions Klawman Carpentry 12 07-30-2010 02:03 PM
Delta table saw blade guard problem RDS Tools 7 03-07-2008 03:29 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
