B & D Chuck - Tools - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 10:49 AM   #1
Rewards Points: 286
B & D chuck
I went cheap and got the B & D that HD sells for $49. Corded 1/2 inch chuck 7 amp. I find it has adaquate power for mixing thin set but am dissapointed with the chuck performance. The chuck tends to loosen up and needs retightening. All the 1/2 drills I looked at were keyed. Is there a drill with a beter performing chuck or is this as good as it gets in the keyed chuck variety. I really can't justify spending a lot since the drill isn't going to be used that much. Can I get a better holding chuck for 20 dollars more in a Porter Cable?
Jim F is offline   Reply With Quote
Old 09-09-2010, 12:22 PM   #2
47_47's Avatar
Rewards Points: 62
I was taught to tighten a chuck first at one hole then do the other two. You could also look into replacing the chuck with one made by Jacobs.
47_47 is offline   Reply With Quote
Bosch keyless, self locking chuck Bluwolf Tools 1 12-28-2009 06:40 AM
Drill Chuck Key cellophane Tools 5 11-22-2009 07:01 PM
Ryobi chuck key Jacobs equivalent for DP101 bbmonster Tools 3 10-08-2009 08:53 PM
Keyed or Keyless chuck? Ultrarunner2017 Tools 4 12-27-2008 06:46 AM
did i fry my hammer drill's chuck ? amakarevic Tools 5 04-15-2008 01:48 PM
