Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 10-13-2012, 07:04 AM   #1
art canvas stretcher tools
Hello!
I intend to make a canvas stretcher..I know all there is the know about canvas making,BUT..the large pieces of equipment I used to use are no longer available to me.
In place of using a frame cutting machine,I probly will use a box mitre saw. The problem is,I have no idea which tool to use as a substitute for the big staple machine that whacks inch-long staples into wooden 2x4's. Basically what I'm asking,is: what is the best and easiest way to join two pieces of wood,both cut a 45 degrees?
Sorry if my question is a bit rambly..
giodiy is offline   Reply With Quote
Old 10-13-2012, 07:21 AM   #2
If your talking about what would amount to just a picture frame out of 2 X 4's then Tite bond II and some 3" long screws, one in each corner, one in the top and one coming in from the side would work.
A Kreg Tool is another way.
giodiy (10-28-2012)
Old 10-13-2012, 07:26 AM   #3
Moderator
kwikfishron's Avatar
They make a gun for those corrugated fasterers if that's what you're talking about. http://www.nailgundepot.com/Senco-SC...2-Details.html
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
giodiy (10-28-2012)
Old 10-13-2012, 01:10 PM   #4
Tool Geek
PaliBob's Avatar
Once you cut the four 2x4's to make the frame, You may have a problem holding them in place while you connect them.
If the total outside length is less than 15ft then a
Ratcheting Band Clamp may help.
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
giodiy (10-28-2012)
Old 10-28-2012, 06:19 PM   #5
That'd be perfect if it wasn't so expensive..any chance I could buy the staples then just whack then in with a hammer?
Old 10-28-2012, 06:21 PM   #6
The frame would need to hold a considerable amount of tension, but your suggestion would seem to be strong enough. Thanks
Old 10-28-2012, 06:22 PM   #7
Super Moderator
Yep---go to an old fashioned hardware store and ask for corrugated fasteners
Old 10-28-2012, 06:30 PM   #8
Perfect!I will do that, then..thanks a bunch!
Antique tools...built to last! spaceman spif Tools 11 09-13-2011 08:49 AM
Tools for a newlywed beginner mephysteaux General Discussion 9 09-24-2010 11:43 PM
What to do with all the shop tools when the shop master passes away ??? JohnFRWhipple General Discussion 8 06-21-2010 08:32 PM
need information regarding powered drain cleaning tools Pipe7000 Tools 1 10-18-2009 02:05 PM
