Ariens Snow Thrower - Tools - DIY Chatroom Home Improvement Forum
Old 12-17-2007, 03:26 PM   #1
Ariens Snow Thrower
boobs
xavierarmadillo is offline   Reply With Quote
Old 12-17-2007, 04:03 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 638
yet the pinion gear axle jumps a bit.
Ayuh,.........
It sounds like the Big chewed up Gear you replaced was the Sympton,+ Not the Cause of your issue......
The Pinion gear should be stabil in it's position,.... If it's bearings are Shot,....
It's climbing up onto the Ring Gear,+ Chewing it up.......
The Whole differential assembley should be rebuilt as a single unit, not just a Part replaced here,+ there.......
Old 12-17-2007, 04:23 PM   #3
breasts
Old 12-17-2007, 04:47 PM   #4
Bondo's Avatar
Rewards Points: 638
That's hard to say without a good Cleaning,+ Inspection......
It could be Bearings or Housings, or Shafts, or...........
And, You need to know the Allowable Tolerances,.....
It might be Better to just bring the differential to the Dealer,+ have them set it up........
Snow Blower Repair Labrador General DIY Discussions 5 06-03-2008 01:26 PM
Ice issue - even after improving ventilation andy1896 Roofing/Siding 13 12-13-2007 12:50 AM
Snow and Ice Shield Over Rolled Roof? Basic_Homeowner Roofing/Siding 17 04-29-2007 11:17 AM
Adding a snow supporting arbor snmhanson Building & Construction 2 12-15-2006 07:21 PM
