-   Tools (http://www.diychatroom.com/f29/)
-   -   Ariens Snow Thrower (http://www.diychatroom.com/f29/ariens-snow-thrower-14536/)
xavierarmadillo 12-17-2007 03:26 PM
Ariens Snow Thrower
boobs
Bondo 12-17-2007 04:03 PM
yet the pinion gear axle jumps a bit.
Ayuh,.........
It sounds like the Big chewed up Gear you replaced was the Sympton,+ Not the Cause of your issue......
The Pinion gear should be stabil in it's position,.... If it's bearings are Shot,....
It's climbing up onto the Ring Gear,+ Chewing it up.......
The Whole differential assembley should be rebuilt as a single unit, not just a Part replaced here,+ there.......
xavierarmadillo 12-17-2007 04:23 PM
breasts
Bondo 12-17-2007 04:47 PM
That's hard to say without a good Cleaning,+ Inspection......
It could be Bearings or Housings, or Shafts, or...........
And, You need to know the Allowable Tolerances,.....
It might be Better to just bring the differential to the Dealer,+ have them set it up........
