Ariens 10ML35 Friction Disk - Tools - DIY Chatroom Home Improvement Forum
Old 12-31-2007, 03:19 PM   #1
Looking for any Info on how to remove the friction disk from this circa 1964 Arien's snow blower. Seems like you have to drop the whole drive system out! No access holes in the frame to remove the shaft that the disk rides on.
Geo
n1naz is offline   Reply With Quote
Old 12-31-2007, 08:23 PM   #2
That is the way we used to do them at our shop. We used to drop the whole carriage assembly. Inspect all the bearings and bushings while your in there. If worn, these will sometimes cause a friction disk failure. I'd hate to see you go through the trouble of replacing the disk only to bave to do it again a couple storms from now.
ewils91 is offline   Reply With Quote
Old 01-03-2008, 03:54 PM   #3
Ok Thanks Sounds like a job for the warm days of summer. I will take a close look at the bearings and bushings while i have it torn apart. Any recommendations as to what Grease or lubricant should be used during re-assembly?
ariens snowblower traction skidad Tools 2 12-17-2007 04:32 PM
Ariens Snow Thrower xavierarmadillo Tools 3 12-17-2007 03:47 PM
