-   Tools (http://www.diychatroom.com/f29/)
-   -   Ariens 10ML35 Friction Disk (http://www.diychatroom.com/f29/ariens-10ml35-friction-disk-14962/)
n1naz 12-31-2007 03:19 PM
Looking for any Info on how to remove the friction disk from this circa 1964 Arien's snow blower. Seems like you have to drop the whole drive system out! No access holes in the frame to remove the shaft that the disk rides on.
Geo
ewils91 12-31-2007 08:23 PM
That is the way we used to do them at our shop. We used to drop the whole carriage assembly. Inspect all the bearings and bushings while your in there. If worn, these will sometimes cause a friction disk failure. I'd hate to see you go through the trouble of replacing the disk only to bave to do it again a couple storms from now.
n1naz 01-03-2008 03:54 PM
Ok Thanks Sounds like a job for the warm days of summer. I will take a close look at the bearings and bushings while i have it torn apart. Any recommendations as to what Grease or lubricant should be used during re-assembly?
