Anyone Use Dremel To Cut Aluminum? - Tools - DIY Chatroom Home Improvement Forum
Old 08-28-2014, 11:07 AM   #1
Rewards Points: 117
anyone use dremel to cut aluminum?
just making crafts out of sheets of aluminum and im burning through fiber cutting wheels like there is no tomorrow.
i was thinking of buying this to see how well it would cut it and hoping they would last a lot longer
http://www.amazon.com/SE-Blade-Mandr...cm_cr_dpwidget
does anyone have any recommendations or should i just stick with
http://www.lowes.com/pd_224901-353-4...d=1207631&Ntt=
echobravo is offline   Reply With Quote
Old 08-28-2014, 11:21 AM   #2
Rewards Points: 1,002
How thick is the aluminum? Carbide wood working tools with a neutral hook are the standard for such work.
Anti-wingnut is offline   Reply With Quote
Old 08-28-2014, 11:39 AM   #3
Rewards Points: 95
I usually just use the heavy duty reinforced cutting discs for aluminum or any really thin metal. I think Dremel has a grinding disk (not a stone but a disk) that might work. Those saw blades might be too aggressive for alum since they have teeth.
Centex2011 is offline   Reply With Quote
Old 08-28-2014, 01:36 PM   #4
They sell those dremel fiber cutting disc on ebay for a lot cheaper..
It really depends on how thick the aluminum is.. A simple table saw with a high count carbide tooth blade would do a wonderful job and leave a nice edge too...
Beyond that, nothing cuts sheet metal like a sheer.. It really depends on what exactly you're doing..
PaulBob is offline   Reply With Quote
Old 08-28-2014, 02:37 PM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Go with the steel saw Blades from Amazon.
Or this one from HF
(I like the HF one piece mandrel better)
http://www.harborfreight.com/6-piece...set-67224.html
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-28-2014, 02:54 PM   #6
Rewards Points: 117
the aluminum is about 1/16 maybe 3/32
its a pc hard drive platter that i am cutting
i tried tin snips, it wasnt cutting maybe cause i have small snips and not larger ones...
thanks for the input
Old 08-28-2014, 03:59 PM   #7
Rewards Points: 144
If it's 1/16" you could clamp it betwee two pieces of angle iron,score with a utility knife a couple times and snap it.If the edge is rough,run a file or sander over it.
Get a good clean line that way and no mess.
mako1 is offline   Reply With Quote
Old 08-29-2014, 04:46 PM   #8
Tool Geek
PaliBob's Avatar
the aluminum is about 1/16 maybe 3/32. . . .
If you go to HF, get one of these:
http://www.harborfreight.com/6-inch-...iper-7914.html
Disclaimer
& Stay Safe
.....Bob Lavery
Question on home inspection & aluminum wiring thinksincode Electrical 11 07-05-2013 09:33 PM
Hot Water Anode: Aluminum vs Magnesium zootjeff Plumbing 4 12-14-2012 04:41 PM
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 12:19 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
