Anyone Rebuilt Own 18V Batteries For Cordless Tools? - Tools - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 01:15 PM   #1
Rewards Points: 562
Anyone rebuilt own 18V batteries for cordless tools?
Heard there isnt much too inside of the battery of a 18v cordless DeWalt battery(as an example). Just a bunch of 1.5 volt batteries soldered, wired together to get to 18 volts.
Heard a battery store could renew them better and cheaper than new. Just got back from one and they wanted 65 bucks to do it and had over the counter replacements with more warrenty for $60,,,but not quite as many _______(forgot what they called it) said if they rebuild its 2100 otc is 2000 and new is only like 1800milliwatts ,,,,,,maybe????????
I know with solar panels you can assemble them yourself for about 10 cents on the dollar of buying one,,,thought should be able to buy batteries for this app. and fix yourself for MUCH less. Anyone done this,,or know someone else that did??
4just1don is offline   Reply With Quote
Old 11-01-2011, 01:52 PM   #2
my son fixed a few cordless batteries at his last job. he took apart the battery and got the number off of the cells and searched the internet for the correct ones. i think most were under 5-6 dollars a piece. I was gonna do the same for my wife's laptop battery but the cost of the new cells was as much as i could get a new battery for from aftermarket manufacturers. dell wanted 150.00 for one.
Old 11-01-2011, 04:44 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 290
I have heard that Radio Shack has the little batteries for replacement.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-01-2011, 06:03 PM   #4
Rewards Points: 254
I have had batteries plus rebuild for my snap-on tools for about 50, over 100 off the tool truck. And they seem to hold a charge longer.
cjm94 is offline   Reply With Quote
Old 11-05-2011, 07:40 AM   #5
Ironlight's Avatar
I took my 14v Milwaukee drill battery to one of those battery stores a few years ago and what i got back from them barely lasted a few months. I would certainly try and do it yourself. All the information you need to do it is available through Google and right there in front of you when you open the battery up, I bet.
Ironlight is offline   Reply With Quote
Old 11-05-2011, 09:46 AM   #6
I am in the process of doing this now. Here are some pics of the inside of a 18V Dewalt. It looks like you have to desolder the top and bottom plates. Then figure out what type of battery you have. Get replacements solder back together. Take a pic to remember the battery configuration. Seems simple enough.
Towerdog2 is offline   Reply With Quote
Old 11-05-2011, 10:00 AM   #7
Framing Contractor
Rewards Points: 118
Not sure that it is worth the hassle. Those Dewalts can be had for $50 each all day long. Probably not safe to mess with if you are not absolutely certain of your skills either,
sixeightten is offline   Reply With Quote
Old 11-05-2011, 10:06 AM   #8
Picture with the tape removed.
Old 11-06-2011, 12:10 PM   #9
In a little over my head
Rewards Points: 706
I recently purchased a couple from batterydepot.com.
The 9.6v I needed seemed like a deal at $25. It looks like the 18v are $46.
Buying these was cheaper than rebuilding at the local battery store.
ratherbefishing is offline   Reply With Quote
Old 11-17-2011, 03:48 PM   #10
While you could solder those together, those are actually welded on. DeWalts use sub-C size batteries in their NICads. The XRP packs have around a 2400mAh cells, where the basic batteries are 1200mAh. If you want to be on the cheap side you can go thru cell by cell and only replace the bad batteries. Only takes a couple bad cells to make a battery suck! Only hard part is getting a good solder joint.
Mikelite80 is offline   Reply With Quote
Testing Batteries With a Multimeter Kent10 Electrical 17 01-17-2011 08:55 AM
Starter tool kits cellophane Tools 16 10-13-2009 02:58 PM
Dead Batteries on power tools pawned Tools 25 11-06-2007 11:11 PM
Battery & Tools Compatability?? GilmoreD Tools 2 10-28-2007 06:24 PM
