Anyone Have An Idea How To Fix Stuck Bit In A Cordless Screwdriver? - Tools - DIY Chatroom Home Improvement Forum
Old 03-18-2014, 05:26 PM   #1
Rewards Points: 143
Its driving me nuts..
I have this drive: BLACK & DECKER 2.4-Volt Cordless Rechargeable Screwdriver
After borrowing it to my friend, I noticed the bit looked really short.. long story SHORT, he must have lost the original that came with it and used another one.. Now its basically shoved in to the point that the phillips crosshead is barely poking out of the drive end..
Any ideas on how to get it out?
oNe
Sean Price is offline   Reply With Quote
Old 03-18-2014, 05:33 PM   #2
Rewards Points: 6,652
Unlock the chuck, then use a pair of pointed nose Vice Grips to try and get ahold of the bit from the side. You may have to do it a bit at a time.
Old 03-18-2014, 06:01 PM   #3
Rewards Points: 143
My apologies good sir..
How do I unlock the chuck on this model? I am not seeing any way to do so?
THanks!
oNe
Old 03-18-2014, 06:13 PM   #4
Rewards Points: 582
does the little black circle on top just push in to release bit???
Old 03-18-2014, 06:14 PM   #5
Rewards Points: 14,014
There is no lock that can be undone.
The bits held in place with a steel ball and metal clip.
Just going to have to use needle nose plyers and pull it straight out.
PaliBob (03-18-2014)
Old 03-18-2014, 07:18 PM   #6
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
A small dab of oil, pair of pliers to grip the bit, pair of pliers to grip the socket.
Twist the bit a few times either direction, then see if the bit will pull out.
gmaint is offline   Reply With Quote
The Following 2 Users Say Thank You to gmaint For This Useful Post:
gregzoll (03-18-2014), r0ckstarr (03-30-2014)
Old 03-18-2014, 07:58 PM   #7
It is actually pressed on during assembly. If you pull it off, it tends to break the plastic fingers holding it on the shaft that is the switch.
Old 03-19-2014, 01:38 AM   #8
iminaquagmire's Avatar
Rewards Points: 338
Try giving it a good tap on a hard surface. It can help break loose any friction holding it in place. I have to do this regularly on my impact drivers. Then as said use some pliers if needed.
iminaquagmire is offline   Reply With Quote
Old 03-19-2014, 07:14 AM   #9
Rewards Points: 582
I said to push it back to see if it has a release on it ...I have a drill and saber saw that release that way...they are called no-chuck quick change...thanks ..ben
Old 03-19-2014, 04:21 PM   #10
The problem is that this tool was not designed that way.
Old 03-19-2014, 08:09 PM   #11
Rewards Points: 143
Thank You Gents.. Issue resolved by use of Needle Nose pliers..
Popped right out and didn't even damage the bit one....err bit! WINK!
Thanks Again!
oNe
The Following 2 Users Say Thank You to Sean Price For This Useful Post:
gmaint (03-19-2014), gregzoll (03-19-2014)
Old 03-19-2014, 08:19 PM   #12
Needle Nose Pliers or Needle Nose Vice grips always work.
Old 03-19-2014, 09:24 PM   #13
Rewards Points: 143
will definitely keep that in mind moving forward.. to think months of using it thusly when so easily remedied!
d@mmit!
oNe
Cordless Cellular Blinds kristan Interior Decorating 8 01-17-2010 09:33 PM
Cordless screwdriver PirateKatz Tools 6 02-16-2009 03:01 PM
Is this a bad idea??? drillbit Building & Construction 3 08-19-2008 09:14 AM
Idea for kitchen peninsula acomiskey Remodeling 3 05-17-2008 02:12 PM
Carpet Idea...Will It Work? Topazprincess77 Flooring 1 03-19-2008 10:47 AM
