Any Info On Underpowered Central Nailer - Tools - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 11:55 AM   #1
any info on underpowered Central nailer
My new Central Pneumatic Pro Series nailer underpowered when nailing at angles...any idea of how to increase power...air pressure at the tank is 90 lbs
Dale Shetler is offline   Reply With Quote
Old 02-16-2011, 01:30 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,... Have you Oiled it,..??
Internal resistence slows 'em down, Alot....
Old 02-17-2011, 10:39 PM   #3
underpowered nailer
thanks for the note BONDO...yes to the oil...just was informed today I can make an adjustment to the psi near the psi meter on the gun side of the compressor...will try it and see what happens...
dale
Old 02-18-2011, 09:19 PM   #4
remodeling pro
First try cranking up the tank pressure to the upper end of the tools recommended operating pressure.. Look at the labels on the tool and you will see the operating pressure range, usually 90-120 psi. Second, what diameter and length hose are you using. Less expensive pneumatics are not as efficient and often do not tolerate small (1/4") diameter and/or lengths over 50' for hose.
troubleseeker is offline   Reply With Quote
Which cordless nailer should I buy? Mike2181 Tools 8 09-23-2009 01:04 PM
Underpowered Central AC? dvation HVAC 14 07-26-2009 09:44 PM
Hardwood Nailer and Compressor - HorsePower/PSI or SCFM? hwood Flooring 3 03-04-2009 03:11 PM
stupid question about a brad nailer? cyclonic Carpentry 17 08-23-2008 06:55 AM
