Any Ideas On. Fabbing Up A Siding Brake?????? - Tools - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 03:05 PM   #1
bsa_bob
Rewards Points: 150
Any ideas on. fabbing up A siding brake??????
I sorta want to do this job myself. I haven't got the proper brake in length, other that the 2x2' pieces of angle iron I used to start with. I made a few short bends. thought maybe you might have thought up, something to make the longer bends ...homemade or otherwise bob s
bsa_bob is offline   Reply With Quote
Old 03-28-2013, 03:45 PM   #2
kwikfishron's Avatar
Rewards Points: 202
Good luck with that one....for what you're wanting to do I'd be looking at finding a used one and then just re-sell it when your done.
There are deals out there if you look. I just did a quick search in my area and came up with this. http://eugene.craigslist.org/tls/3613788342.html
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
bsa_bob (03-28-2013)
Old 03-28-2013, 04:03 PM   #3
Rewards Points: 13,300
Home Depot rents them.
Old 03-28-2013, 05:19 PM   #4
bsa_bob
Rewards Points: 150
Thank you Again fellas bob s
Old 03-29-2013, 04:34 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
There are usually some on Craigslist. Try to find one that doesn't have the hinge all butchered up. Some guys clamp their coil stock and use the jaw as a straightedge. Then they cut into the hinge and screw it up. Scratched up finish on your trim from there on. You can always resell it when you are done.
Old 03-29-2013, 04:40 PM   #6
I've yet to see one of those antique wedge style brakes worth the time to try and use.
Guess once you have used the new style you get spoiled.
Old 03-29-2013, 05:01 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
the only thing to be weary of with rented brakes is the condidtion of them.. ive used a couple that were really banged up.. when that happens more intricate bends are harder to make.. hemming aluminum is near impossible with a un tuned brake
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
bsa_bob (04-06-2013)
Old 04-06-2013, 03:07 PM   #8
bsa_bob
Rewards Points: 150
Smile
brake for trim
I had a guy show me what to do,@ my local lumber yard.Its piece of cake, marked out all my dimensions on my coil stock, went down and bent all my window trim up in 20 minutes.on their loner brake. no charge! bob s things do go my way once in a blue moon.
Old 04-12-2013, 09:22 PM   #9
Check a local tool renal place, usually around a 100 a day. But if you really want to make one look up pictures of malco flashing brakes, that will give you an idea of what you will need to do.
jsbuilders is offline   Reply With Quote
The Following User Says Thank You to jsbuilders For This Useful Post:
bsa_bob (04-13-2013)
Siding advice, please MT Stringer General DIY Discussions 5 08-04-2009 03:32 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
