Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-26-2008, 09:54 PM   #16
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Any good stud finders?
I have had good results with a cheapie but horrible results with an $80 craftsman (it went back).
There is a neat one I found recently when I was doing my podcast on "first toolbox" tools. Its purely magnetic. It just hangs off the nails that hold up the lath or drywall. Check my sig, go to the toolkit podcast post and scroll down to magnetic studfinders for more info.
If you don't want to go to that trouble here are the links.
Tool kit Show
http://www.handyguyspodcast.com/30/e...6-the-tool-kit
Link to stud finder
http://www.handyguyspodcast.com/the-...ore?B00065DP74
Brik is offline   Reply With Quote
Old 03-01-2008, 04:37 AM   #17
I can't use a stud finder the darn things always point to me.
RobertS is offline   Reply With Quote
Old 03-07-2008, 05:34 PM   #18
Despite being well warned against wasting my money on a stud finder, I did buy a Zircon i500 multiscanner today. I am happy to report that I have been getting some good info from the device.
Watching the DVD which came packaged with the unit prior to using it, I found that for my walls, plaster over wood lathe, the best mode is the metal mode, then look for nails.
That helps a great deal. I am able to discriminate between nails and larger metal objects such as BX cabling or plumbing in that nails usually produce a much weaker signal, and are passed by very quickly.
The normal stud finding modes (regular and deep scan) don't seem to do very much good on most of my walls, as was stated by others here.
But I am finding the i500 quite useful in locating the wiring. I can detect most BX using metal mode, and all of the Romex using either metal of AC mode.
I have learned in the few hours I have been experimenting with this tool that one must be very patient with it, and learn how to interpret it's responses.
So far, I would say that the i500 is certainly more use to me than nothing at all.
I paid $40 for it at Home Depot.
FW
fw2007 is offline   Reply With Quote
Old 03-21-2008, 07:24 PM   #19
Finish Carpentry Pro
Go to eBay and search for a "neodymium n50" They are the strongest magnets you can buy. You can get a 1" x 1" cylindrical magnet for around $10, and it has a pull strength of over 100 lbs. I can find studs on my plaster walls with a lessor magnet.
Quiglag is offline   Reply With Quote
Old 05-15-2008, 08:37 AM   #20
I have to ask, how do you get the magnet off the nail without pulling the nail out? Slide it to the side?
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 73 04-07-2013 08:35 PM
what's a good stud finder? handbanana Tools 16 12-07-2007 04:01 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
Stud Finder problem... kalaniwavo Carpentry 4 02-26-2006 08:24 PM
