Antique Saber-saw Value? - Tools - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 03:23 PM   #1
Rewards Points: 502
Antique saber-saw value?
I picked up a cheap saber-saw at the local restore place. it later dawned on me that this thing might actually have some value to a collector.
Its a Sunbeam no.76 saw in the original (but beat up) box, with plenty of blades (sort of like regular saber-saw blades, but completely non-interchangeable), rip/circle guide and manuals. I think it dates from the 50s. Its got no handle (you just hold onto the cast Al housing) and a toggle switch for off and on.
forresth is offline   Reply With Quote
Old 12-31-2010, 04:39 PM   #2
Experienced
Jackofall1's Avatar
May be an old tool to the rest of the world, but that would be a new tool to the UP, just took awhile to get there......
Old 09-30-2011, 05:37 PM   #3
Does anyone know where blades for this saw can be purchased? I found one in an old barn here in Ohio and only has just the one blade which is damn sharp! Somebody (the farmer maybe) must have put a new cord on the saw 'cause when the switch is "OFF" the saw runs but when in the "ON" position the darn thing is off. I can't believe it came from the factory that way but maybe!
oldsoldier is offline   Reply With Quote
Old 09-30-2011, 05:42 PM   #4
Rewards Points: 502
I have never seen a blade for sale that was like them. The work involved to make new blades out of existing saber saw blades in not practical for everyday use. I could only see that as being an option if you just want to have a running antique tool.
The Following User Says Thank You to forresth For This Useful Post:
oldsoldier (09-30-2011)
Old 09-30-2011, 06:17 PM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
are those the ones that have 5 or 6 holes in the shank and a little nub coming off the back?
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-30-2011, 06:27 PM   #6
Rewards Points: 502
5 holes; 2 above 3 below the nub. The holes have no apparent use. The nub looks like about 1/4"x1/2", but that is without a ruler
Old 09-30-2011, 06:32 PM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
that sounds like the one i'm thinking of. haven't seen any of those in MANY years
Old 09-30-2011, 06:46 PM   #8
Rewards Points: 502
ya, all the blades I have are Sunbeam brand blade. I bet they were proprietary.
It would be a very simple design, but looks like a very material inefficient design. the shank with the drive nub is even thicker material than the cutting blade, so it would take a significantly bigger piece of steel than just he blade size. Its no surprise that they don't still make them.
Old 09-30-2011, 06:59 PM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
did a quick search and found these
they sold for $14 on ebay last month
Old 09-30-2011, 07:07 PM   #10
Rewards Points: 502
well, I guess my saw and blades are worth at least $20 then
Old 10-01-2011, 02:07 AM   #11
Yeppers, and I sure would give ya 20 bucks for 'em if we were a bunch closer in distance. I'll be at the VFW National Home (Eaton Rapids) in December but you'll be deep in snow by then.
Old 10-01-2011, 02:09 AM   #12
I did do the ebay thing and Craigs list also but found nothing in the here and now for sale.
Old 10-01-2011, 06:24 PM   #13
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
there is on ebay right now for $5.99 + $20 shipping. do a search for vintage sunbeam saw
Old 10-01-2011, 08:46 PM   #14
model 76
Yeppers, I have taken notice of that ad........but I only need the saw blades. The ad is for only the SAW with no blades included but I do thank you for the info!.
Old 01-03-2012, 02:44 AM   #15
sunbeam hand saw.
For Forresth, do you still have the saw and blades and do you wish to sell them? If so I can also be reached at billcale@gmail.com
v/r Littlebilly
littlebilly is offline   Reply With Quote
Refinish antique brown Mahog door NJMC Painting 9 11-27-2009 11:25 AM
How do I remove paint from Antique Door Hardware water_cutter Painting 7 02-24-2008 03:50 PM
cutting laminate with a saber saw? darsunt Flooring 6 02-22-2008 08:42 AM
saber saw limitations? darsunt Carpentry 4 02-21-2008 10:15 AM
Rebuilding a jam for an antique front door? Minnesota Gal Carpentry 6 12-01-2007 09:26 PM
