Angle Grinder Arbor Size - Tools - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 10:53 PM   #1
angle grinder arbor size
Do all 4 1/2" angle grinders use the same 4 1/2" blades? I'm seeing different arbor sizes on different blades- are these for 4 1/2" tools other than angle grinders?
OtisDriftwood is offline   Reply With Quote
Old 01-11-2011, 07:59 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
The "standard" arbor these days on a angle grinder in the US is 5/8-11. There are a couple grinders that use a metric M10 or M14, but these are pretty rare. a few smaller grinders and most pneumatic models use a 3/8-24 arbor
It sounds confusing, but the good news is none of it really matters for the most part. usually when you see a wheel listed as 7/8 bore, it will fit on just about any non-air operated grinder, when you use the nut to hold it on to the shoulder. A wheel listed as 5/8" will also fit most grinders, as those usually thread on the arbor.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-11-2011, 08:40 PM   #3
Thanks! I bought an old angle grinder on eBay for a steal, I'm usually more satisfied with old, corded, hunk-o-metal power tools than cheap out of the box Chinese junk. Never owned an angle grinder in my apartment days, but I keep finding odd jobs that wear out my dremel now that I'm a homeowner.
Old 01-11-2011, 09:01 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Originally Posted by OtisDriftwood View Post
Thanks!
No problem. if you have any other questions or problems just ask. There are a lot of pretty knowledgable folks here in the tool forum, and if none of those guys are around I'll try to help you !!
angle grinder question itin1200 Tools 8 07-13-2010 08:07 PM
Is it wise to tuck point with an angle grinder? jpearson311 General DIY Discussions 5 12-30-2009 07:54 AM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 05:12 PM
4" Angle Grinder trout_baller Tools 9 08-11-2007 09:47 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
