ALL-PRO Forced Air Heater Always Runs Slow - Tools - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 11:58 AM   #1
ALL-PRO forced air heater always runs slow
I have an "ALL-PRO' bullet heater (50,000 to 85,000 BTU) that will fire up, but it fires up like a real big burst like it always did when holding the igniter, then cuts way down within 2 seconds to a low fire about two(2) inches in diameter, looking in from the front. Won't stay lit after I release the igniter. Guess it isn't enough fire to keep the thermocouple hot. Anyone have this problem or any suggestions?
Thanks in advance.
Ted
tg5398 is offline   Reply With Quote
Old 12-08-2011, 12:09 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,... Fuel fired, or propane,..??
Sounds like crud in the fuel delivery...
The Following User Says Thank You to Bondo For This Useful Post:
tg5398 (12-13-2011)
Old 12-13-2011, 04:08 AM   #3
I don't know what happened, but on the third tank I tried,it started working again. Maybe setting all summer had something to do with it. OK, now.
Ted
Old 12-13-2011, 06:16 PM   #4
What size tank are you using?
mbryan is offline   Reply With Quote
Forced Air Heater problems retoid HVAC 8 11-06-2010 11:27 AM
Lennox furnace blower runs slow ventport HVAC 9 02-21-2010 04:42 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
