Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 05-07-2012, 01:04 PM   #1
air staple gun not firing
I have a bosch 17 gauge crown air staple gun. It worked for the first 10 staples then stopped. I unjammed a staple but the gun wont fire. Air pressure is ok, when I pull the trigger I hear the air hiss. What else can I check? 647-202-0898
heidinielsen is offline   Reply With Quote
Old 05-07-2012, 09:56 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
you mean the 18 gauge, they dont make a 17 gauge.
souinds like the drive pin is jammed, open up the magazine where you load the gun with staples. you should see a u shaped peice of metal sticking out from inside the barrel of the gun.. using a flat head or robertson screwdriver, lightly tap it back inside the nailer..
did you oil the nailer before you used it?
woodworkbykirk is online now   Reply With Quote
Staple up, warmboard or gypsum concrete? jelly HVAC 6 08-17-2011 12:35 AM
Through the joist into the canister, staple? epeterson777 Electrical 12 02-08-2009 10:06 PM
remove staple without damaging NM DIYGST Electrical 4 01-04-2009 10:01 AM
What does "crown" staple mean? Speedball Tools 10 11-25-2008 09:09 PM
wire staple removal madmax55555 Electrical 8 07-03-2006 06:29 PM
