Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-03-2009, 07:42 PM   #1
air compressors?
porta cable or bostitch air compressors?
ron0805 is offline   Reply With Quote
Old 12-03-2009, 10:50 PM   #2
Floor Sweeper
air compressors?
Is there a particular model of either brand name that you are considering?
junkcollector is offline   Reply With Quote
Old 12-04-2009, 10:40 AM   #3
air compressors?
porta cable
6 gallon
150 max psi
Bostitch
6 gallon
150 max psi
Old 12-04-2009, 10:42 AM   #4
air compressors?
porta cable
6 gallon
150 max psi
Bostitch
6 gallon
150 max psi
im looking for a combo kit for under $300
Old 12-04-2009, 12:30 PM   #5
Master General ReEngineer
Bondo's Avatar
air compressors?
Ayuh,... There's not alota Quality difference,..
So,... Buy the 1 with the features you like...
Old 12-04-2009, 02:45 PM   #6
air compressors?
I presume you mean "Porter Cable." In any case, I think Bondo is right.
Old 12-05-2009, 08:04 AM   #7
air compressors?
I purchased a Bostitch 6 Gsllon pancake three years ago...Came with finish nailer...
Can't imagine life without it. Runs great, oil free and it has helped me in so many ways.
Good luck and enjoy!
Han'D' is offline   Reply With Quote
Old 12-05-2009, 01:08 PM   #8
air compressors?
i was on lowes website to read the reviews about the bostitch 6 gallon,it was'nt very good most of the people that bought it didnt like it and alot had to return it.
With the porter cable it got good reviews on the home depot website.
So i think im goin with porter cable
Old 12-07-2009, 11:38 AM   #9
Household Handyman
air compressors?
One thing I note here: Both of these units are "6 gallon/150 max psi". That tells me they probably are the oilless type compressors. These type units do not have an oil bath which lubricates the internal mechanisms of the compressor unit. They rely on plastic/"Teflon-type" bushings for wear control. One indication of these is the high "max P.S.I." of these type units. These units are noted for high pressure build-up, but at low C.F.M. (Cubic Feet per Minute) of volume. You can find special compressors which have just the opposite, higher CFM output/ less pressure build-up. These are usually an oil-bath type compressor. That's why you have to determine what your needs are: Do you need a compressor to run say-one or two nail guns intermittently, which require moderate pressure and low CFM build-up? OR-do you need a compressor which will run a sander/paint gun/air grinder/etc. which require both high C.F.M. and high pressure? Just a thought here, David
Air compressors DBRhino Tools 29 12-12-2009 02:51 PM
Rewiring air conditioning compressors jmwilson@usg Electrical 9 09-02-2009 12:31 PM
Rebuild domestic refrig compressors hvaclover Appliances 0 06-24-2009 09:58 PM
repairing air compressors drewhart Tools 5 11-28-2008 02:26 PM
