Air Compressor Question - Tools - DIY Chatroom Home Improvement Forum
Old 10-06-2013, 04:32 PM   #1
Rewards Points: 47
I just purchased a air compressor and it is a 240v compressor. I have piped it up for air but still need to run wiring. It plugs into the pressure switch but not sure how. Is there a plug that I run to the wall outlet or do I just run wire straight to it? Thanks for the help. I don't have a plug yet but am going to run the wire here in the next couple days.
tucker0104 is offline   Reply With Quote
Old 10-06-2013, 05:36 PM   #2
Most 240V compressors can either be hard wired or set up with a plug and outlet. If you don't expect to move it, I'd hard-wire it and save the expense of a plug and outlet.
RoyalAcresRod is offline   Reply With Quote
Old 10-07-2013, 12:29 AM   #3
Rewards Points: 258
If I'm not mistaken you will need a disconnect real close to the compressor. So the easiest way to do that is a plug in.
redman88 is offline   Reply With Quote
Old 10-07-2013, 08:22 AM   #4
PoleCat's Avatar
Rewards Points: 1,646
We just used a DPDT switch on ours.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
