Air Compressor Problems - Tools - DIY Chatroom Home Improvement Forum
Old 04-27-2008, 08:42 PM   #1
I have a brand new Industrial Air Compressor with little hours on it. The compressor belt sqeewls at start up and then seems to fluxuate RPMs during its cycle. What can be the problem?
DAVID2347 is offline   Reply With Quote
Old 04-28-2008, 05:26 AM   #2
Rewards Points: 530
Can you tighten the belt? Being used very little, maybe the belt has stretched. Sounds as if it is slippping. If no adjustment, maybe try some kind of belt dressing.
Old 04-28-2008, 06:24 AM   #3
I thought that could be th e problem but would that make change RPMs?
Old 05-15-2008, 07:10 AM   #4
Rewards Points: 530
If the belt has glazed places on it from slipping, I think it could affect steady rpm's. Sorry about the delayed response. I forgot about this post as I do not come here often. Brand new? Did it come with oil in it??
Old 05-15-2008, 10:14 AM   #5
Yes it had Oil in it from shiping. The new problem is once the compressor shuts off at 150 PSI. it will kick back on right away as soon as you use an air tool.
Old 05-17-2008, 07:08 PM   #6
Rewards Points: 150
what is you PSI to the tool ???
comp is offline   Reply With Quote
Old 05-18-2008, 09:16 AM   #7
145psi I also have a water seperator but it does not seem to be working
i installed it according to the instructions but I am still getting lots of moistier with the
sandblasting gun.
Old 05-18-2008, 03:54 PM   #8
compressor nto keeping up with the CFM requirements of your air tool?
What is the compressor rated at for the PSI you are operating the tool at? And what is the stated air requirements from the tool manufatcurer for the same PSI?
have2goski is offline   Reply With Quote
Old 05-18-2008, 05:00 PM   #9
Right now I am only using the compressor to sandblast and to air tires. the compressor is rated at 12-13 cfm at 90psi.
Old 05-19-2008, 07:17 AM   #10
Mold!! Let's kill it!
Rewards Points: 2,012
Make sure the "unloader" is working. It should have a valve that releases trapped air in the cylinders when it shuts off. The idea is that the next time the compressor starts it is starting with "empty" cylinders. When the compressor cycles and shuts off on high pressure, you should hear a hiss as the unloader releases this air. If not, then the motor is starting under load making the belt slip and squeal.
Old 05-19-2008, 12:53 PM   #11
It does not let the air out unless you manually shut off the compressor even then it is only a little air. Do you think the switch is shot?
Old 05-19-2008, 01:48 PM   #12
Every time it shuts off automatically, the unloader should purge the compressed air out of the cylinders. As soon as the motor stops, mine opens and bleeds air for a second or two. Then, the next time the motor starts, it does so without a compressed air load. It should be on or near the pressure switch. They can stick at times. If it is, see if you can operate it manually to free it up. Otherwise, you'll need a replacement.
