Air Compressor Problem, Help Please - Tools - DIY Chatroom Home Improvement Forum
Old 12-20-2007, 04:46 PM   #1
Air Compressor Problem, help please
my air compressor when i start it will build up air, up to 60lbs. then the motor keeps running, but the air quits building up, it use to build to around 120lbs. i have no idea how to fix this or what could be wrong if anyone knows please post thank you
sam_0213 is offline   Reply With Quote
Old 12-20-2007, 04:55 PM   #2
Home Improvement Guy
ron schenker's Avatar
Have you drained the water out of it lately?
What make is it?
ron schenker is offline   Reply With Quote
Old 12-20-2007, 09:23 PM   #3
Is your compressor equipped with a line regulator and is set to a limit of 60?
Is your compressor's belly valve (air bleed/water drain valve) fully closed?
End Grain is offline   Reply With Quote
Old 12-20-2007, 10:05 PM   #4
it is a magnum brand, i currently have the drain valve open to see if that helps but i think i have done that already and it didnt help... the regulator is not set at 60 it is set at 120
Old 12-20-2007, 10:20 PM   #5
Oldguy
Rehabber's Avatar
You prolly have a check valve sticking or going bad
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-20-2007, 10:22 PM   #6
thank you
