-   Tools (http://www.diychatroom.com/f29/)
-   -   Air Compressor Problem, help please (http://www.diychatroom.com/f29/air-compressor-problem-help-please-14628/)
sam_0213 12-20-2007 04:46 PM
my air compressor when i start it will build up air, up to 60lbs. then the motor keeps running, but the air quits building up, it use to build to around 120lbs. i have no idea how to fix this or what could be wrong if anyone knows please post thank you
ron schenker 12-20-2007 04:55 PM
Have you drained the water out of it lately?
What make is it?
End Grain 12-20-2007 09:23 PM
Is your compressor equipped with a line regulator and is set to a limit of 60?
Is your compressor's belly valve (air bleed/water drain valve) fully closed?
sam_0213 12-20-2007 10:05 PM
it is a magnum brand, i currently have the drain valve open to see if that helps but i think i have done that already and it didnt help... the regulator is not set at 60 it is set at 120
Rehabber 12-20-2007 10:20 PM
You prolly have a check valve sticking or going bad:furious:
sam_0213 12-20-2007 10:22 PM
thank you
