Air Compressor Issues - Tools - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 09:17 PM   #1
Air compressor issues
My father-in-law has an air compressor that wants to shut off several times before reaching the "cut-off" point. It might shut off at 80 psi or even 100 or 120 psi. It doesn't do it every time, but when it does, he can shut it off and turn it back on several times and it will climb to the cut off point. Any ideas on what could be causing this?
Nichols2 is offline   Reply With Quote
Old 05-01-2011, 09:19 PM   #2
Framing Contractor
Rewards Points: 116
Sounds like the switch.
sixeightten is offline   Reply With Quote
Old 05-01-2011, 09:26 PM   #3
he already changed the pressure switch and it didn't change a thing as far as the way it was operating. I suggested that to him when he was talking to me about it and that was the first thing he did to try to correct the problem, so I am hoping someone has run into this problem before.
Old 05-01-2011, 09:27 PM   #4
Framing Contractor
Rewards Points: 116
It is either the switch or the regulaor. My money is still on the switch.
The Following User Says Thank You to sixeightten For This Useful Post:
Nichols2 (05-01-2011)
Old 05-01-2011, 09:30 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
one other possibility; there is a thermal overload that is auto reset and it just looks like him flipping the switch does something.
The Following User Says Thank You to nap For This Useful Post:
Old 05-01-2011, 09:33 PM   #6
I will check it all out when I am down there and let you all know what I find. I haven't looked at it yet but have plans to here soon. Thanks for the advice. I will look at all the possiblities.
Old 05-03-2011, 05:03 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
I'm going with a pressure switch. You might try sraying some contact cleaner in it before you start replacing things.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Nichols2 (05-04-2011)
