Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 12-06-2006, 12:36 PM   #1
ADKstorm's Avatar
Question
Air compressor and framing nailer for DIY
I am a weekend do-it-yourselfer looking to buy an air compressor to aid in a project basement finishing of a 12’ x 12’ room. One tool I would like to use is a framing nailer with an air compressor to frame the partition walls. I really don’t want to spend a lot of money on a compressor. I have spoken to a tool manufacturer on their framing nailer and they keep saying they recommend an air compressor with 6 CFM @ 90 PSI. Doesn’t CFM mean the recovery rate of the compressor? Is it not true that CFM is the flow of air into the tank that the compressor motor can produce? If so, CFM is only a term used when the compressor is running....when off, you simply have PSI until it lowers to the point that triggers the compressor on to repressurize the tank at the desinated flow rate (CFM). ......maybe I am wrong, but this seems to be logical
If I have 90 PSI coming through the regulator then it should work fine right?
If I have to waiting a few minutes between shooting a half a dozen nails, its no big deal.
Would I be better with a 150 max PSI compressor or one that is 125 max PSI?
Compressor?
Porter Cable 150 max PSI, 6 gallon – 2.6 SCFM @ 90 PSI ($180 US, includes brad nailer)
or
Campbell Hausfeld 1.3 H.P. 125 max PSI, 15 gallon – 3.7 SCFM @ 90 PSI ($180 US)
Framing nailer?
Grizzly 21 degree round-head model #H7665 ($100 US)
I was hoping to spend under $200 for an air compressor and will deal with a wait time.
Thanks for the help and suggestions!!!
ADKstorm is offline   Reply With Quote
Old 12-07-2006, 10:02 AM   #2
Oldguy
Rehabber's Avatar
Either compressor will work for what you want to do. (My advise would be to buy the largest compressor you can afford, because you will use it for many things in the future.) Get a name brand nailer (Porter Cable or any other.) and then sell it on EBay to recoup most of your money. Avoid no names, quality is questionable and a framing nailer is a very powerful potentially dangerous tool.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-07-2006, 10:35 AM   #3
I dare not to use air tools yet ... worring it being dangerous... and all those air compressor... connectors... air hosts.. oil/lubricating... filtering.. gives me headache...
I prefer electrical... although I cannot really comment between the two yet as I have yet to try the air tools...
KUIPORNG is offline   Reply With Quote
Old 12-07-2006, 04:59 PM   #4
KUI****G,
I have been where you are with regards to air tools. Even though I used them at work (mostly impact wrenches) I still saw no need for them at home. THEN, I found a cheap brad nailer and bought it. Now, I don't know how I ever got by without one. While "cheap" is not the way to go, I have gotten more use out of this tool than I ever expected so I am happy. If I were to be doing heavy duty work (like framing) I would get a more expensive and safer tool to do the job.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-08-2006, 08:28 AM   #5
I have the Portar Cabel one with the brad nailer, go with that one. It is very good, works good for nailers.
OsNaP is offline   Reply With Quote
Old 12-09-2006, 08:56 PM   #6
ADKstorm's Avatar
Question
How about this one?
RIDGID
1.8 Hp Running, 4.5 Gallon Oil Free Air Compressor
Model OF45150
http://www.ridgid.com/MenuDriver.asp...AIR-COMPRESSOR
I have other Ridgid tools and like them quite a bit. This compressor is more expensive than I wanted to spend but according to the write up, It will run two framing nailers at the same time.
-------In addition-------
I was thinking of buying the following to go with the air compressor....what about these items?
Framing Nailer:
http://www.grizzly.com/products/H7665
or
http://www.aircompressorsdirect.com/...roducts_id=584
Finish nailer:
http://www.grizzly.com/products/H6144
50' Hose:
http://www.grizzly.com/products/g8113
or
http://www.amazon.com/Porter-Cable-6...633446-1292866
Swivel Whip Hose:
http://www.harborfreight.com/cpi/cta...temnumber=1824
Coupler Set:
http://www.harborfreight.com/cpi/cta...emnumber=94024
Inline oiler:
http://www.aircompressorsdirect.com/...roducts_id=421
Anything important am I missing?
THANKS
Old 12-11-2006, 07:29 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
For longevity - Nothing beats an Oil fed Compressor.
For operating in very cold weather - Nothing beats an oil-less compressor.
We do, have a RIDGID Oil-fed compressor that looks almost exactly like the one you have that we use strictly for framing because of it's capacity. If you want to run more than 2 guns and have plenty of air... hook up a large auxilary tank between the compressor and the guns.
If you want a DIY compressor (used every now and then) that can run 2 framing guns at DIY speed (non-heavy volume-continuous use), then the larger sized pancake compressors actually can do the job.
As far as the Framing nailers (Grizzly and Harbor Freight) - I have no comment since I have zero knowledge and experience with them.
FWIW: We use Porter cable, Hitachi, Bostich, Dewalt, Paslode...
- Build Well -
Old 12-14-2006, 09:17 AM   #8
We bought a Model OF45150 about 2 years ago, and it has been
an excellent compressor for framing. Will easily keep up with 3 men
doing stick framing. The only time it fell behind was with 2 men
nailing off sheathing (about 10 nails per second non-stop using
Senco scn60 coil nailers ). It has never had a problem, and is
a great general purpose compressor. Paid about $240.00 for it
at Home Depot.
jbob is offline   Reply With Quote
Old 12-16-2006, 02:33 PM   #9
ADKstorm's Avatar
Question
at Home Depot.
Have you used this compressor for other uses? ....finish nailers, brad, stapler, tire inflator, air gun, paint sprayer, etc?
thanks
Old 12-17-2006, 08:34 PM   #10
I've used it for everything you mentioned, plus I have in a pinch used
it for a texture hopper gun. It will keep up if shooting at a moderate
pace. I have never used it with a paint sprayer though...I have an
airless I use for most of my painting.
I've been happy with it in every situation
Old 01-08-2007, 04:53 PM   #11
Any compressor should work for you. If you're working alone, you have to do measure, cut, nail which is going to give any compressor more than enough time to recharge.
You have options.
Buy a new compressor.
Buy a used compressor.
Oilless, or Oiled
I recommend the oiled one. A good properly maintained oiled compressor will run for many years without problems. It is also quieter than the oiless ones. If you want you can look into used compressors as well. The 20 gallon 2hp-ish ones pop up for sale all the time around. I wouldn't buy a used oil-less compressor though.
For size, someone said buy the biggest you can afford. I usually agree with that unless you're going to be transporting it a lot or you're only useing it for the nailgun around your home in which case I would go small and cheap. A larger compressor though gives you the flexability to start running automotive air tools though.
As for nailguns if it's for one project I'd either buy a cheap harbor freight gun or go on eBay and buy a used name brand one from a reputable seller. When you're done stick it back up for sale and it won't cost you much.
Another option you have is the Pasolode cordless nail guns. Those things are great. Put the battery in, put the gas cartrege in, and it's ready to go. It's great because the whole setup fits in a little orange case, much more compact than a compressor, no cords, no air lines, no waiting for the compressor to fill up.
The downsides:
The batterys don't last forever.
Gas cartreges are not free.
The guns are about $300 each. With a compressor you can stick any gun you want on there, with the Pasolodes you have to buy the entire kit for each gun you want. Odd things like roofing nailers and palm nailers (another great invention) arn't available.
Basically if you're using it around your house the only upside to the cordless is if you ever just want to put in five nails or so you wouldn't drag out the compressor but you would take the Pasolode out. If you're transporting it from place to place and don't spend much time at those places the Pasolode is a huge conveince.
Tmb9862 is offline   Reply With Quote
Old 01-08-2007, 06:08 PM   #12
HarryHarley
HarryHarley's Avatar
Looks like your list is a fine start for your project. My only suggestion is the the Griz nailer on your list is a finish nailer not a framing one. At 34 degrees I believe it would use a clipped head nail. I use a 21 degree framer and use full head 2 3/4 stainless nails. Love it. Good luck and have fun.
HarryHarley is offline   Reply With Quote
Old 01-08-2007, 06:11 PM   #13
HarryHarley
Oh forgot to mention, the biggest problem is finding the exact nails you want/need. So stick with a common angled nailer....
Old 01-09-2007, 02:11 PM   #14
ADKstorm's Avatar
http://www.grizzly.com/products/H7665 is a full head 21 degree framing nailer
and
http://www.grizzly.com/products/H6144 is a finish nailer
I think before I buy the nailers, I will contact Grizzly and inquire what other brand nails work are compatable
Old 01-09-2007, 02:20 PM   #15
I got a Pasolodes cordless (NEW) from internet(don't mention who, but you know, it is the only one)... cost me $100 bucks include everything... still in my in-law place in US... will get it once I visit them in March break... if you are in US... you can get deal like this from internet...
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
