Air Compressor Fan Removal - Tools - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 09:32 PM   #1
Air compressor fan removal
I have a DeWalt D55167. The fan has a few broken fins and I want to replace it, however, the fan is attached to the main rod that runs the flywheel / belts etc.
There is no set screw and Im not sure if anyone knows of an easy way to remove an air compressor fan like this.
ordonyez is offline   Reply With Quote
Old 01-09-2012, 09:44 PM   #2
Framing Contractor
Rewards Points: 98
Toolpartsdirect.com has a schematic for that. Is there an allen screw on the shaft?
Has to be something simple, the part is $2.41
sixeightten is offline   Reply With Quote
Old 01-09-2012, 10:00 PM   #3
Ive been on toolpartsdirect but the microfiche dosnt show how it comes off. No there's no allen screw on the shaft. i agree it has to be something simple but I cant figure it out which is why I posted, Im sure someone should know.
Old 01-09-2012, 10:07 PM   #4
Just pryed it off with a screw driver - problem solved easy enough
tile removal with heat MLMIB Flooring 9 08-12-2011 07:45 AM
prepping walls after wallpaper removal.... diy'er on LI Painting 10 11-09-2010 09:57 AM
Tree Removal - determining which ones the1hangingchad Landscaping & Lawn Care 4 08-16-2010 08:15 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
