Air Compressor Drain Valve - Tools - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 11:26 PM   #1
I just bought a Porter Cable air compressor - my first. When I go to drain it after use, I'm actually tightening (screwing it back into the tank) the valve to release the air and water vapor. I would think loosening it (unscrewing the valve) would drain the unit. Does this sound right to anyone??
Red Truck is offline   Reply With Quote
Old 02-10-2010, 11:39 PM   #2
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Into the tank opens the valve to drain. Clockwise tightens the valve.
Kevin
Kevin M. is offline   Reply With Quote
Old 02-11-2010, 06:20 AM   #3
Originally Posted by Kevin M. View Post
Into the tank opens the valve to drain. Clockwise tightens the valve. Kevin
Yes, Because if you were to take the valve out with air behind it you could make a dangerous projectile. So its engineered to screw into the tank and release the air.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 02-11-2010, 08:36 AM   #4
Great thanks! That makes sense.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Double Check Valve installation (and a few other questions) secutanudu Plumbing 0 04-17-2009 08:42 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
