Air Compressor Does Not Shut Off - Tools - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 11:24 PM   #1
Air compressor does not shut off
it just runs and runs and never goes above about 40 psi.please help
Philsmess is offline   Reply With Quote
Old 05-30-2009, 11:49 PM   #2
Custom Cabinet Maker
check all the lines and the Drain valve for leaks. I can think of only a few things: a leak OR the pressuretrol is bad. I would hunt for leaks as I first suggested. If you have an air hose attached disconnect it, run the compressor and see it problem goes away. If nothing changes then problem is in the compressor itself. If this is an older unit may also be a hole in the air tank itself from internal rust. If that turns out to be the problem STOP USING IT IMMEDIATELY scrap it.
skymaster is offline   Reply With Quote
Old 05-31-2009, 11:45 AM   #3
Idiot Emeritus
Rewards Points: 1,492
What type is it? Oil-lubed, or oilless? Direct-drive, or belt-drive?
With a bit more info, we can help more.
Rob
micromind is offline   Reply With Quote
Old 06-01-2009, 07:35 PM   #4
oil compressor sears craftsman[the smaLL one] thank you
Old 06-02-2009, 08:37 PM   #5
Idiot Emeritus
There are a number of possibilities. Usually, the oil-lubricated pumps don't fail, it's usually something else.
While it's running, feel around (careful, some parts are pretty warm!), and possibly you can find the leak. Concentrate on the piping from the pump to the tank. Make sure the unloader valve is closed. Feel around the pump cylinder for a blown gasket.
The intake filter could be clogged as well.
Once it builds up any pressure, does it hold it after it's turned off? If so, the problem isn't with the tank, it's either the pump or piping.
Rob
Old 06-05-2009, 09:34 PM   #6
strube1369
strube1369's Avatar
Unhappy
My apologies if this is too obvious but just thought I'd mention spraying soapy water sure makes finding leaks easy.
strube1369 is offline   Reply With Quote
Replacing shut off valves with broken off handles pcampbell Plumbing 14 08-18-2014 06:10 AM
Community water shut off zevon Plumbing 14 10-03-2008 08:16 AM
Toilet to Go won't shut off Evildad Plumbing 4 09-28-2008 01:26 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 01:44 PM
