Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 07-02-2012, 10:00 PM   #1
P Marage's Avatar
Air compressor(C&H) stuck. Tries but wont start.
Hi folks... I have a basic horizontal Campbell Hausfeld Air Compressor(8 gal).
Simply put. I flip the power switch on, it hums for about 1-2 seconds then trips off. The pump never turns on. I only hear the capacitor trying to energize the pump.
Fluids have always been at recommended levels and its never been flipped over or mistreated. It sits in my shed, light use, tire pumping, small brad nailer ect.
Thanx in advance for any thoughts, Ideas and or solutions.
I cant determine the correct category I should be posting this in but im sure many in construction who use compressors have had this problem so I chose this one..
(Admin feel free to move this thread or let me know where it belongs so I can move it)
P Marage is offline   Reply With Quote
Old 07-03-2012, 05:10 AM   #2
An old Tradesmen
Moved to tools forum.
Old 07-03-2012, 06:28 AM   #3
Bleed all of the pressure from the tank. If it does not start, with or without pressure in the tank, I would suspect the motor capacitor. If it does not start with pressure in the tank, but does start with no pressure in the tank, I would suspect the check valve.
Old 07-03-2012, 11:02 PM   #4
P Marage's Avatar
Thanx Dexter, do you know how to test the cap? I can hear it powering so it's working to some degree. Can a cap still power if it's faulty? I'm no electrician by any means but I thought they either worked or didn't, No in-between.
Old 07-04-2012, 09:49 AM   #5
And, just to confirm, this is with no pressure in the tank, correct? If so, your local motor shop can test it for you.
Old 07-04-2012, 09:42 PM   #6
P Marage's Avatar
Zero pressure in the tank.
Old 07-04-2012, 11:26 PM   #7
Missouri Bound's Avatar
What fluids? The compressor pictured is an oil less model. The motor itself is most likely unserviceable. And it's the contactor (pressure switch) you hear, not a capacitor. Unplug it, take the cover off and try and spin it by hand. If it sits in a shed it could be rusted up, or perhaps some wires were chewed by rodents. Post a model number if you can.
Do you want it your way or the right way?
Old 07-04-2012, 11:28 PM   #8
An old Tradesmen
Key phrase. UNPLUG IT before trying to turn by hand.
Old 07-04-2012, 11:36 PM   #9
beenthere....I edited my post to enforce that suggestion....and thanks for the idea
Old 07-05-2012, 01:08 AM   #10
P Marage's Avatar
Thanx Missouri. I tried to turn it by hand and it won't. (assuming your talking about the white disk with fins on it, front side) Not sure about the oiless part because it has a plug with a dipstick and an oil tin displayed. I have never had to fill the reservoir as the dipstick reads full.
Model HL550100 (exact as photo)
Old 07-05-2012, 08:05 AM   #11
I looked up your model number. I stand corrected, the pump clearly hasa dipstick which indicates it is not oil less. If you can't spin the fan it's either rusted up or it siezed for one reason or an other. The parts are ridiculously expensive to replace. If you have any mechanical savy you could try some minor dissasembly and see what went wrong. Does the pump itself show any signs of corrosion?
Old 07-05-2012, 08:46 AM   #12
Super Moderator
Are you trying this on an extension cord?
Some of mine will only work when plugged into a wall outlet on a strong circuit.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
DexterII (07-05-2012), Missouri Bound (07-05-2012)
Old 07-05-2012, 06:39 PM   #13
An old Tradesmen
Dang, you are on the ball, never thought about that.
Old 07-05-2012, 08:07 PM   #14
Yes, a very good point. Very easy to overlook, especially when it has worked previously, but just because it did doen't always mean it will. And the higher than normal temperatures around the country definitely put a strain on the flow of electricity.
Old 07-05-2012, 10:38 PM   #15
Super Moderator
I have a heck of a time ---my compressors both hate cords---and my small one would just hum in the cold weather until the oil warmed up---synthetic oil cured that issue.
compressor wants to start but won't wetbar HVAC 13 06-17-2010 07:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 02:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 09:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 11:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 08:05 PM
