Air Compressor Blow Off Valve Help - Tools - DIY Chatroom Home Improvement Forum
Old 12-11-2008, 09:46 PM   #1
My Father-in-Law has a cheap hot-dog compressor (Meijer "Shop Force") that pumps up and blows off about 50% of the the time. It doesn't seem that there is a problem with the compressor, just that the settings for the pressure relief valve and the switch are toooooo close. Is there a way to adjust either? I've searched for the owners manual on-line, but no luck. I won't be seeing him or the compressor until just before Christmas, so I can't look at it on my own.
Thanks in advance.
shoeheel is offline   Reply With Quote
Old 12-12-2008, 05:21 PM   #2
Rewards Points: 266
A few years back I had the same problem with an inexpensive compressor. I ended up adjusting the pressure relief valve by removing the ring (comes off like a keyring) pulling off the plastic cap, loosening the locknut, and turning the valve stem in a turn. I then tightened up the locknut and replaced the cap and ring. As long is the pop-off pressure is just set to close to the cut out pressure of the pressure switch, there is little danger in doing what I just said. It was just adjusted too close at the factory.
You could also open up the pressure switch, and turn down the large nut that has a + - on it. This nut adjusts both the cut in and cut out. Turn it counterclockwise about a turn. Keep in mind, this will lower the maximum output pressure acordingly.
What pressure does the compressor shut off at? 110? 115? 125?
junkcollector is offline   Reply With Quote
White-Rodgers zone valve 1361 wiring ??? srauner HVAC 1 12-07-2008 12:50 AM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 07:52 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
