Air Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 04-24-2008, 05:07 PM   #1
Air Compressor
I have a Craftsman air compressor, its about 2 years old. I cant for the life of me get the air to stop leaking out of the hose ends (hose to compressor and hose to tool) i have I used plumbers tape and really screwed them together, but the leaks continue.
Any thoughts?
-J
Jshakour is offline   Reply With Quote
Old 04-24-2008, 05:29 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
Striped threads? Try getting a new hose. Use plumbers dope and see if that helps. Also if you are using teflon tape you want to wind it onto the male part in the same direction that the female part screws on, usually clock wise. If you wrap it anti clockwisa the tape gets torn off before the threads grab it.
USP45 is offline   Reply With Quote
Old 04-24-2008, 05:32 PM   #3
it tried another hose and I got the same result.
Ill try the plumbers dope.
-J
Old 04-25-2008, 07:08 AM   #4
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Mine leaks around the fittings themselves. I too tried all the tape and dope and cheater bars to tighten them and it never helped. I have finally resolved in buying another 50' airhose to get that thing away from where I'm working so I don't have to hear it. I keep saying that I am going to order some well made ends but those japan junk kits that blowes sells that has the tire chuck, air gauge, nozzles, ... is too tempting to pass up.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 04-26-2008, 07:47 AM   #5
Rewards Points: 530
Maybe a good wire brushing ( electric) of the threads? Are you sure the air is coming from around the threads? How is the clamped parts on the hose?
If not sure where the leak is, try some leak detecter or soapy water to pinpoint the leak. I have on ethat constantly leaked down. This went on for a loooong time as I do not use it very much. Heheh, my drain plug on the bottom of the tank needed tightening.
Old 05-24-2008, 05:38 PM   #6
RedsRR's Avatar
make sure its threads leaking and not the female coupler itself? cheap ones and old ones will leak. the rubber seals go out in there and theyre junk.
RedsRR is offline   Reply With Quote
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 11:17 AM
air compressor - dangerous???? reds_21 General DIY Discussions 23 04-25-2008 10:17 PM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
Heat Pump compressor trips circuit breaker joejean HVAC 3 08-28-2006 12:15 PM
