Air Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 12-26-2007, 07:08 PM   #1
Air compressor
I have a Sears 3hp 15 gal. compressor. I turned it on the other day and it runs but dos not build up any pressure. I can feel air coming out the top. It sounds like it has water in the tank. i opened up the valve underneath and couldn't get any water out of it. Any ideas? Thanks
f15097 is offline   Reply With Quote
Old 12-26-2007, 07:31 PM   #2
Oldguy
Rehabber's Avatar
If air is coming out of the intake filter, you have a stuck or worn out reed/check valve
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-27-2007, 12:34 AM   #3
Reed valve
How do you un-stick or repair a reed valve? The air comes from the plastic cover on the top of the compressor. Thanks
Old 12-27-2007, 10:52 AM   #4
Oldguy
Rehabber's Avatar
If the air filter goes into the cylinder head, remove the cyl head, be careful with the gasket, and it will be reusable. The cheaply made chinese compressors will have two rectangular plates (loose) in two milled slots. If the slots are worn oblong, the compressor is history. If not, clean and lube with a light oil (any air tool oil will work fine) reassemble and go
Old 01-06-2008, 09:38 PM   #5
Rewards Points: 150
Hey I just repaired my compressor. I could not figure why there was no air build up?
The line going into the tank was broke at the brass conection. this was hard to spot. The fitting broke at the flarred end.
deck hand
deck hand is offline   Reply With Quote
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 05:05 PM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 12:17 PM
air compressor - dangerous???? reds_21 General DIY Discussions 23 04-25-2008 11:17 PM
Air Compressor Timer 69-er Electrical 7 10-02-2007 04:40 PM
