Advice Needed On Bostitch PN100 O-ring Replacement - Tools - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 03:37 PM   #1
Advice needed on Bostitch PN100 o-ring replacement
Bought an o-ring replacement kit for my PN100 palm nailer. There's a schematic but no service manual. Seems pretty straight forward: just pull the screws on the cap and go to it.
...or so it seems..
Cap screws are pulled & the cap isn't coming off. Pulled the nose piece too, but no effect. There aren't any other fasteners I can see, but still the caps tight on there.
What an i missing? Any help appreciated.
RolHammer is offline   Reply With Quote
Old 06-01-2013, 09:41 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
go to www.ereplacementparts.com and punch in your model number.. a diagram will come up of hte tool parts pulled apart. that should help
woodworkbykirk is online now   Reply With Quote
Old 06-01-2013, 10:05 PM   #3
Oh, I've got the diagram. It looks like a pretty straight up affair from that.
Which is why I find it confusing that the cap's not releasing.
Old 06-02-2013, 09:51 AM   #4
Update: Nevermind, I got it. Took a lot more prying than I'd expected. Swapped out the o-rings and the thing's running like a top now!
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 06:19 PM
Floating floor water damage - advice needed rumiat Flooring 3 05-28-2012 03:38 PM
Basement windows being replaced - Advice needed! jjchronowski Windows and Doors 2 04-24-2012 11:44 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
Subfloor Overhaul - Advice Needed kadams2345 Flooring 39 11-19-2011 02:02 AM
